Chamfer Radius Gadget - New Gadget
Postby Jeff E. » Thu Jan 22, 2015 7:03 pm
Chamfer Radius is a new gadget that enables you to easily create a radiused edge on a closed contour. The gadget adds the capability to make a radius on either an inside contour or an outside contour. I've included a few preview examples for you to browse. I have also included a screen shot of the ball mill tool set up I used to create the examples. While I use it as an alternative for the regular angled chamfer for deburring metal, I think you will find many uses for it in wood working.
--- ATTENTION ---
-- Chamfer Radius is based on Chamfer In & Out
-- Chamfer In & Out - is a modified version of the Vectric Chamfer Gadget v1.1
-- The various modifications were done by me - Jeff Elliott. If you would like to contact me I can be reached via the Vectric forum.
-- In no event will the author be held liable for any damages arising from use of this gadget.
I have attached the "Chamfer Radius" for your use. Works great for me, but your mileage may vary. Use caution until you have tested it in your environment.
To install the "Chamfer Radius", unzip then place a copy of the Chamfer Radius folder in the standard gadget location on your computer. On my computer it would be placed in the following directory:
C:\Users\Public\Documents\Vectric Files\Gadgets\Aspire V4.5
After placing it in the correct directory, restart your Vectric software and you will see the new "Chamfer Radius" entry in the gadget drop down menu.
Enjoy,
Jeff
Chamfer Radius.zip
(162.52 KiB) Downloaded 1612 times
Jeff E.
Re: Chamfer Radius Gadget - New Gadget
Postby Fleming » Fri Jan 23, 2015 1:28 am
Excellent tool! Many thanks.
Cobblewood Carver
Fleming
Postby scottp55 » Fri Jan 23, 2015 1:38 am
Thank you Jeff!! :)
GMH
scottp55
Postby Rick O. » Fri Jan 23, 2015 7:03 am
Thanks, that looks very useful!
I notice that it is in the Aspire directory. Will this gadget also work with V-Carve?
RickO
Rick O.
Model of CNC Machine: CNC router
Postby Jeff E. » Fri Jan 23, 2015 7:45 am
Rick O. wrote:Thanks, that looks very useful!
Rick O,
As far as I know it should work in the latest version but I don't have Vcarve Pro so I have not tested it. Give it a try, the worst thing that could happen is you will have to uninstall it by dragging the folder to the trash.
Enjoy,
Jeff
Jeff E.
Postby DanB. » Fri Jan 23, 2015 6:28 pm
Thank you Jeff!
Just installed it in my VCarve Pro v7.514 and it works great. I can find a lot of uses for this.
Dan
DanB.
Model of CNC Machine: Homebuilt 24" x 48"
Postby Jeff E. » Sat Jan 24, 2015 5:12 pm
DanB. wrote:Thank you Jeff!
Dan
Dan,
Thanks for the feedback - now I know it works on VCarve pro as well as Aspire.
Jeff
Jeff E.
Postby T.McCaw » Sun Nov 08, 2015 9:42 am
Working great in V Carve Pro 8.024
Many thanks
Tom
Nanaimo BC
T.McCaw
Model of CNC Machine: Multicam 3000
Postby Ms Wolffie » Mon Nov 09, 2015 1:01 pm
Thank you so very very much for the files and photos.
Perfect timing, only 2 days ago I was trying to do something like that and failed BADLY :x
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Postby Jeff E. » Mon Nov 09, 2015 6:55 pm
Ms Wolffie and Tom McCaw,
Thanks for the feedback - glad you like the gadget.
Jeff
Jeff E.
Postby davemartin88 » Fri Nov 20, 2015 2:49 pm
I may have misunderstood but what tool is used for this gadget? Is it a 1/4" end mill or a ball nose bit? Thanks.
davemartin88
Model of CNC Machine: CAMMaster Stinger II
Postby Jeff E. » Fri Nov 20, 2015 6:28 pm
Dave,
You can use either flat bottom or ball end mill. If you wan a smooth radius you use a ball end mill. A flat bottom mill will leave a stepped effect. Most people probably use the ball end mill.
Jeff
Jeff E.
Postby davemartin88 » Fri Nov 20, 2015 9:22 pm
Thanks, I was looking at the tool description showing the end mill and then at the previews and wondering how you gut such a smooth finish. Will download this gadget, looks very useful! Thanks again.
davemartin88
Postby buckeyes66 » Tue Nov 22, 2016 10:42 pm
I could not get this to work in vcarve pro
buckeyes66
Model of CNC Machine: cnc shark
Postby IslaWW » Tue Nov 22, 2016 11:19 pm
Desktop or Pro? Gadgets do not work in the desktop versions
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Next
Return to Gadgets - User Submissions
