Chamfer Radius Gadget - New Gadget
Re: Chamfer Radius Gadget - New Gadget
Postby Jennifer » Sat Dec 10, 2016 2:32 am
Hi,
I have been wracking my brain trying to figure out how I can make a radiused fretboard using vcarve pro. Basically it is a long narrow rectangle with the top surface curved. Will this gadget allow me to effect that?
Jennifer
Jennifer
Model of CNC Machine: 1000 x 750mm CNC router 3axis
Postby Adrian » Sat Dec 10, 2016 11:05 am
You would need a 3D model of the shape you want or you could try the moulding toolpath.
Postby Sawnsand » Tue Jan 02, 2018 4:11 pm
I did some asking about an issue with Vectrics Chamfer gadget, and they did a new upload on their gadget collection to fix the issue. I also asked about the Chamfer Radius gadget that I got off this forum last year.. here is that exchange
Mark Moran (Vectric Ltd.)
Jan 2, 14:47 WET
Hello Craig,
Thank you for the follow-up email.
I am afraid that we would not be able to amend a gadget that we have not written.
You would need to get in touch with the author to see if a later version is available.
Regards,
Mark.
Mark MORAN
Support Manager
Crc
Jan 2, 14:38 WET
Thank you for the quick response, I'll look into it when I get home after work.
There is another gadget that has an odd situation. It's called Chamfer Radius, and I first downloaded it from the Vectric Forum a while back, it's not available from the Vectric gadget collection. It was while I was using the previuos version of Vcarve Pro, 8.5 I believe. I had it set up and used in a number of files that I transferred over to 9.0, and they work fine, unless I recalculate all the toolpaths in one of those files. ReCalculating one or more of the toolpaths other than the Chamfer Radius toolpath works fine, and the Chamfer radius toolpath stays in working order, as long as I don't recalculate it.
It seems to work as a holdover on files originally set up in Pro 8.0/8.5 and used in 9.0... but it will not work when installed in 9.012 and creating a new toolpath. I get an error message that some lines of code are not good...(I don't have the error in front of me, I could send it if needed.)
I know this is not a Vectric gadget, but if there is someway to make it work in my current version of V Carve Pro, I would appreciate it...
_________________
I do use this gadget and if it could be fixed to work in VCarve Pro 9+, I would be very grateful...
Craig C.
Sawnsand
Model of CNC Machine: Probotix Meteor
Postby SteveNelson46 » Tue Jan 02, 2018 5:07 pm
I installed this gadget in Aspire V9 and I can't seem to make it work. Maybe I'm missing something? I think it needs to be modified for use in all of the V9 versions.
EDIT: It does work in V 8.5 though.
SteveNelson46
Model of CNC Machine: Camaster Stinger with Recoil Lathe
Postby Sawnsand » Tue Jan 02, 2018 11:41 pm
Here is the Vcarve pro message I get when I try to apply the Chamfer Radius gadget. The gadget starts fine and lets me pick the option I want, hit OK and this is what shows up
Sawnsand
Postby Adrian » Wed Jan 03, 2018 8:45 am
Jeff needs to change his gadget to work with the latest version. It's not a Vectric gadget.
Postby BallardMillworks » Wed Jul 04, 2018 6:58 pm
Any chance of an update? I tried and get same error posted earlier.
This would be wonderfult to have!
BallardMillworks
Model of CNC Machine: Shopbot Buddy
Postby paricklesher » Thu Sep 27, 2018 5:03 pm
Hello,
Is there any way it could get upgraded to work with v9 or v9.5?
I would be willing to donate some money.
paricklesher
Model of CNC Machine: CNC Router Parts Pro
Postby Adrian » Thu Sep 27, 2018 5:51 pm
Jeff hasn't been on the forum for a while.
Postby Adrian » Sat Sep 29, 2018 9:01 am
I've changed the lines in the gadget that stopped it working in the latest versions. I don't like amending other peoples code but Jeff appears to have gone awol.
It can be installed using the instructions Jeff posted on the first post of the thread or you can rename the zip file to vgadget and install by double clicking the file or the Install Gadget item in VCarve/Aspire.
Chamfer In and Out.zip
(57.35 KiB) Downloaded 194 times
Postby paricklesher » Fri Nov 02, 2018 4:52 pm
Thank you very much!! It seems to be working now from my quick test.
paricklesher
Postby badgersurfer » Thu Jan 10, 2019 4:09 pm
Adrian wrote:I've changed the lines in the gadget that stopped it working in the latest versions. I don't like amending other peoples code but Jeff appears to have gone awol.
Slightly confused here. I downloaded your modified gadget and placed in the correct location but when I run it in Vcarve Pro 9.5 is just comes up as a Chamfer Tool and not a Chamfer Radius tool. Any ideas?
badgersurfer
Model of CNC Machine: xcarve
Postby Adrian » Thu Jan 10, 2019 5:42 pm
This is the radius version. The postings got mixed up somewhere along the line.
Chamfer Radius.zip
(162.57 KiB) Downloaded 111 times
Previous
