Plate Easel - stand
Plate Easel - stand
Postby Turtle49 » Tue Oct 12, 2010 12:52 am
This is the third iteration of my plate easel. It is 7/16" thick and made from three pieces. You can use it for decorative plates, platters...Ipads etc. It will set on a flat surface or hang on the wall.
I have thought I would offer it to anybody that wanted it. The toolpaths are setup, but obviously I do not take any responsibility for anything that happens if you cut it. You are responsible for checking all the settings prior to using it!
Plate Stand-Easel.zip
(266.16 KiB) Downloaded 753 times
Enjoy!
:D
Tim Hornshaw
www.HornshawWoodWorks.com
Turtle49
Model of CNC Machine: 4' EZ-Router and Blurry customs SK25
Re: Plate Easel - stand
Postby PaulCNCMann » Tue Oct 12, 2010 12:58 am
Thanks for sharing Tim,
It really is beautiful up close, and made a great iPad stand.
Paul
Paul Mannhardt
PaulCNCMann
Postby sawmiller » Tue Oct 12, 2010 1:53 am
yes,
thanks tim, i was admiring it, and it's finish, at memphis
dan
ps, wife says thanks also.....
In the heart of Tn
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Postby jimwill2 » Tue Oct 12, 2010 2:38 am
Very nice! Nice work and very generous... thanks for sharing it.
Jim
Jim Williams
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Postby bgriggs » Tue Oct 12, 2010 3:58 am
Tim,
It was a pleasure talking to you. Thanks for the file, I can use an Ipad stand.
Bill
bgriggs
Model of CNC Machine: Warp Drive Project R&P
Postby highspeed » Tue Oct 12, 2010 2:31 pm
Tim,
Looks cool,
Thanks Mike :D
highspeed
Postby Turtle49 » Tue Oct 12, 2010 3:58 pm
You are all very welcome!
:D
Tim Hornshaw
Turtle49
Postby Hunterland » Tue Oct 12, 2010 11:23 pm
Tim Thank you very much for sharing. I enjoy viewing your work as it is always high quality! It is this kind of sharing that makes this site a step above the rest. Thanks Again and keep up the good work. Don
Hunterland
Model of CNC Machine: prs standard
Postby Penman » Wed Oct 13, 2010 5:40 am
Thanks a lot Tim,
have downloaded to cut later. My biggest problem is lack of imagination and laziness.
Thanks again
Roger.
Penman
Model of CNC Machine: Shopbot B 32 Alpha
Postby NormanAlbert » Wed Oct 13, 2010 8:44 pm
Thanks a lot Tim. With a little modification I 'm useing 1/2 corian to make mine. At some point I'll have to return the favor. Norm
NormanAlbert
Postby Turtle49 » Wed Oct 13, 2010 9:22 pm
NormanAlbert wrote:Thanks a lot Tim. With a little modification I 'm useing 1/2 corian to make mine. At some point I'll have to return the favor. Norm
Hey Norm,
The corian should work fine. The only suggestion I have, is the slot is inset from the back of the legs far enough to accommodate the round over bit I used. You may want to consider sliding the enlarged pocket (for the 1/2" corian) forward and keeping that edge. But even if you didn't it should still probably work.
Good luck, and post your results.
Tim
:D
Tim Hornshaw
Turtle49
Postby MarkJohnston » Fri Nov 12, 2010 4:57 pm
Thanks Tim for the plate easel file. I’m new to the CNC world so I’m trying to do as many things as I can to learn as fast and much as I can. Your work is fantastic to say the least.
I was wondering if I could scale up the easel from 7.5 inches to say about 9 inches. Is there a method of doing that with ease? I tried the offset Vectors method but it scales in all directions and I think I would want to scale the length and not the width so much. I also made the back piece bottom a little wider to make it a little less tippy when placing a larger item on it. It’s not quite a pretty but seems to work better.
Thanks again for all your posts.
Mark
MarkJohnston
Postby Turtle49 » Fri Nov 12, 2010 5:19 pm
I would have to say that there isn't a real easy way of doing what you would like. To increase the height while maintaining the width, you would have to change the angle on the tenons that are incorporated into the back piece.
Good luck,
Tim
:D
Tim Hornshaw
Turtle49
Postby dustybugger » Sat Nov 13, 2010 1:42 am
Thanks for the great file. As you can see, I grabbed it to use with my next years chairity fund drive donation.
Thanks again I enjoy your work.
John V
dustybugger
Postby Turtle49 » Sat Nov 13, 2010 2:29 am
Thanks for posting pictures, the color looks great!
Tim Hornshaw
Turtle49
Next
Return to VCarve - Gallery
