VCarve Test Cuts
Postby Paul_n » Thu Jan 12, 2006 12:48 am
Here I go again..... Having to much fun. This time with circles (ohs).
Paul
(159.47 KiB) Downloaded 365 times
(158.56 KiB) Downloaded 365 times
Paul_n
Model of CNC Machine: ShopBot PR96
Sack of Oh's 2
Postby Phil » Fri Jan 13, 2006 4:34 pm
Sock of Ohs #2 is intriguing. How did you do it?
Phil
Postby Paul_n » Fri Jan 13, 2006 8:04 pm
Hi Phil...
I'll try my best to give you the steps.
First, it was a scan of a picture from a book.
The scan was converted to vectors, using 'potrace'.
The results were as in the "rings" picture, attached.
Then after "much" cleanup time, and remove of unwanted vectors, ended up with as in "rings02"
picture attached.
The 2 pictures that were posted before are of the same artwork. Just different objects were selected.
In the '01' , all the vectors were selected. In the '02', the one you asked about, only the inside vectors
were selected.
See a closeup in the attached "rings03" picture.
I hope this is somewhat clear. If not, ask again !!
Thanx
Paul
(396.67 KiB) Downloaded 352 times
(316.34 KiB) Downloaded 311 times
(94.12 KiB) Downloaded 329 times
Paul_n
Sack of Ohs
Postby Phil » Sat Jan 14, 2006 4:10 pm
Hi Paul.
the close up - sack of ohs 3.jpg really shows the necessary details. Did you have to close all of the partial circles individually? That would take a lot of time.
The project has a real 3-D look. Did you actually cut the file? This technique could be used to create Celtic knots.
Thanks for sharing your work.
Phil
Phil
Postby Paul_n » Sat Jan 14, 2006 4:36 pm
Phil....
I do not know why the 'screen-print' looks like that, but amost all of the vectors
were closed, only had to hand work a few.
If you would like to email me your email address, I'll send you the file, and you
can cut it. I've not cut it as yet.
Do you have a copy of VCW ?
Paul
Paul_n
Postby dighsx » Mon Jan 23, 2006 3:44 pm
Here’s another sundial I cut the other day. This one tells you the height of the sun off the horizon. The second picture is a shot of one of my quality control officers checking my work.
(59.93 KiB) Downloaded 363 times
(57.96 KiB) Downloaded 359 times
Take it easy.
Jay (www.cncjay.com)
dighsx
Postby BrianM » Mon Jan 23, 2006 7:32 pm
That's really nice Jay, but surely the dog casts too wide a shadow to get an accurate time?
Mind you, if it's anything like our dog, the time is always meal time!
Brian
BrianM
Vectric Staff
Postby dighsx » Mon Jan 23, 2006 9:20 pm
Thanks Brian and yes for George the quality control officer it's always mealtime or naptime.
Here's a close up of the dial in the last post and of a dial I finished today.
The yellow dial isn't for telling time (although it will) it's for finding true north. You line both dials up so they read the same time and the direction it's pointing is true north.
(256.73 KiB) Downloaded 316 times
(299.16 KiB) Downloaded 334 times
Take it easy.
dighsx
Postby dighsx » Sun Jun 25, 2006 12:59 pm
In between some other jobs I ran this one. It's for the back of a bookcase; it'll get mounted to the top of the bookcase. It was really easy to do with the new VCPro, took about 5 minutes to create. I picked a western font I had found someplace.
Stats: 90-degree 0.5inch V-Bit. Total size was about 19X6inches and it was just painted plywood. And man was the plywood crappy. Had a ton of voids in it. But the guy I made it for was happy so I'm happy.....
Seeing the picture in the garden makes me think I should look into making some garden signs.
(137.09 KiB) Downloaded 339 times
Take it easy.
dighsx
Paint Mask
Postby brockadeau » Sun Jun 25, 2006 7:31 pm
I bought some Avery paint mask, applied it, burnished it, cut out the graphics, painted it black, (with some missed days inbetween), and tried to peel it-- All I goe was a sticky residue left after barely being able to peel it off (actually I gave up and belt sanded it off).
I think I should have not left it on so long, but a looking for help or advice if anyone has any--this is a really great forum-- tons of helpful information and links-- thanks-- Jack
brockadeau
Postby dighsx » Sun Jun 25, 2006 7:45 pm
There is a max amount of time you can leave it on before it bonds with whatever it's on. I think it's 12-24 hours but I could be wrong. I normally get it off soon as the paints dry to the touch, but you have to be careful not to pull the paint off. Best if you can take it off while the paints wet but I have waited overnight to take it off before..
My bet would be you waited too long to take it off.
Take it easy.
dighsx
Postby RoutnAbout » Sun Jun 25, 2006 8:20 pm
Brockadeau,
I've have used contact paper or a masking tape. When the tape or contact paper is pulled from the job. I aways use Bestine to remove the gummy residue. It won't harm or dissolve paint or plastics.
Don
Roll of Honor <-- Never Forget
________
Don
RoutnAbout
Model of CNC Machine: Old Bot with a Rope Pull Start Spindle
paint mask
Postby brockadeau » Sun Jun 25, 2006 10:31 pm
You know it's always wise to do a sample first-- I'm glad I didn't mask off the two 4x8 sheets of extera mdf I have to cut for a customer--and leave it on for a week--There were no instructions with the mask--I was thinking maybe I should have applied some heat to help remove it, but time is probably the culprit here-- as well as the fact it was on a somewhat porous laquered surface (only 2 coats of laquer on mahogany mdf)-- and thanks for the info about the Bestine-- Never heard of it before, but I will get some to try out-- keep the tips comming, as I think they can help us all-- Jack
brockadeau
Postby Burchtree » Sun Jun 25, 2006 11:40 pm
Hi all
I have removed mask within hours after painting and up to two days after. It was a great deal harder to remove even after only one day. One theory I have is because my finish is dry but not cured the finish is still out gassing. Maybe those vapors are combining with the glue to make it harder to remove. This is only a guess on my part and nothing more.
Dan
Burchtree
Postby Burchtree » Mon Jun 26, 2006 1:15 pm
Hi
I have been looking for information on Avery paint mask. This is about all I could find.
Description:
Avery GraphicsTM Paint Mask is a flexible calendered vinyl with removable adhesive, which will
cleanly remove from most OEM surfaces up to 1 year when, removed promptly after painting and
curing cycles. Designed for computer cut stencils used in making painted signs.
The ( up to one year ) is the shelf life.
Shelf Life: One year when stored at the following temperatures and humidity conditions:
68̊-77̊ F (20̊ - 25̊C) and 50±5% Relative Humidity.
For surface preparation, converting and printing, application and removal instructions, please
refer to the Avery Graphics Instructional Bulletins.
I looked at that and found this.
Adhesive Removers
Use Avery Graphicsä Right-Off adhesive removal formula to remove any remaining adhesive
residue.
Caution: Follow all recommended procedures and safety recommendations on the container label.
Rapid Remover – Adhesive Removal
Formula
The Rapid Tac Company
186 Combs Drive
Merlin, OR 97532-9769
Tel: 541-474-1113
Orange Peel – AR409 Adhesive Remover
GAP
1630 Wilson Ave.
Burbank, CA 91504
Tel: 800-866-8440
About all you can do is
1- Remove the mask as soon as you can.
2- Use an adhesive remover to remove any remaining adhesive.
Dan
P. S. These are only parts of larger documents.
Burchtree
PreviousNext
Return to VCarve - Gallery
Users browsing this forum: t1hog and 9 guests
