Gallery Of Machines
Re: Gallery Of Machines
Postby Dadof2and2 » Fri Apr 25, 2014 7:21 pm
Fine Line Automation Kit 2ft. x 4Ft
Dadof2and2
Model of CNC Machine: Fine Line Automation
Postby scancad » Mon Apr 28, 2014 8:44 am
Here's our Pro Carv Retrofit for Stone Memorial carving. does fine stuff too...
scancad
Model of CNC Machine: Pro Carv
Postby Zambrano » Wed May 21, 2014 11:37 pm
My second cnc router. Shorter than planned.
cutting first job
Painting after galvanizing
Zambrano
Model of CNC Machine: Home made CNC Router
Postby AlanS » Wed Jun 11, 2014 9:17 pm
Here is my Kronos Robotics KRMx02. It is a 27x50 with a 800 watt air-cooled spindle and a 1.5kw VFD.
AlanS
Model of CNC Machine: KRMx02 27x50
Postby woody53 » Sun Jun 15, 2014 2:57 pm
Here is my Probotix Meteor. 25 x 50, 2 1/4 HP Porter Cable spindle. Kent dust shoe picks up all the dust. Harbor Freight dust collector works great, but thinking of doing a mod like posted on here. It does what I want it too, that's what is important.
woody53
Model of CNC Machine: Probotix Meteor 25 x 50
Postby krugshouse » Wed Nov 05, 2014 3:51 am
A picture of my wooden DIY 4' x 8' Blackfoot v.4 machine and control stand.
Have a safe machining day
krugshouse
Model of CNC Machine: Blackfoot v4.2, VCP 8, Mach 3
Postby tatinc2000 » Tue Jan 06, 2015 3:02 am
My homemade pile of parts.
tatinc2000
Model of CNC Machine: Homegrown
Postby miopicman » Fri Jan 16, 2015 12:24 pm
Here is an improved version of my second machine. In the Youtube link I explain the mechanics and electronics of the unit. The original machine was mainly made of mdf and the second was a steel version. This has been upgraded with a better linear bearing system and more substantial leadscrew and nut on all axes. Also the control system has been rationalised into an industry standard enclosure.
http://youtu.be/bBON7Kxcc_w
BTW is there a tutorial on how to use/implement this forum? i.e. how to correctly use all of the facilities along the top of this edit box.
miopicman
Model of CNC Machine: Home built gantry type
Postby mountaincraft » Tue Mar 17, 2015 2:51 am
Been doing all kinds of upgrades to my machine over the last few months...
This is the latest...
Yesterday, I installed a new cable management system for the X axis.. Was tired of broken vacuum hoses... Finally broke down and bought a cable chain, and built a mounting system and supports for it all.. Got a couple more things to do (redo the little block where the chain attaches to the gantry so it can't work loose over time, and install side barriers for the cable chain as it wants to walk a little) and then the problems associated with how I had it before should be resolved once and for all... General wiring looks better now too.. :D
https://www.youtube.com/edit?o=U&fea...id=Epy-xaOm-7Y
mountaincraft
Model of CNC Machine: DIY 4' x 8' CNC Router/Plasma
Postby rig gap » Mon Aug 10, 2015 1:31 am
Recently purchased V-Carve Pro 8, and I'm pleased and amazed at how easy and intuitive it is...I've used other CAD/CAM packages and none are as easy to learn...I'm looking forward to doing some new stuff.
I tried (unsucessfully) to attach pics of my home built CNC router...I'm not sure what I'm doing wrong as I've changed the resolution down to a pretty small size and for some reason they aren't downloading...maybe someone can give me a hint.
Thanks for the great forum and information so far.
rig gap
Model of CNC Machine: Home built aluminum and steel 3 X 4 CNC
Postby cabnet636 » Mon Aug 10, 2015 1:35 am
Are you using the "Upload attachment" at options when posting,, are they jpegs
cabnet636
Model of CNC Machine: CAMaster 508 ATC
Postby rig gap » Mon Aug 10, 2015 2:53 am
I did use the upload attachments, but nothing happened...they are JPEG
rig gap
Postby tatinc2000 » Thu Nov 05, 2015 12:00 pm
New Machine
tatinc2000
Postby mpol0717 » Fri Jan 08, 2016 11:54 pm
Nice looking machine tatinc200. I like that monitor mount a lot. Mind pointing me in a direction to get my hands on one? That looks sharp and a great space saver.
mpol0717
Model of CNC Machine: Openbuilds ox
Postby tatinc2000 » Tue Mar 01, 2016 2:43 am
mpol0717 wrote:Nice looking machine tatinc200. I like that monitor mount a lot. Mind pointing me in a direction to get my hands on one? That looks sharp and a great space saver.
Which motor? The nema motor mounts are cncrouterparts clones and the router motor mount is also a clone but I don't remember where from. The plate it is mounted to is a cncrouterparts z plate clone.
tatinc2000
PreviousNext
Return to VCarve - Gallery
