Okay here's mine...
Completed about two years ago....took exactly one year to build ..start to finish.
2 months was nothing but sourcing and AutoCad work. I did all the machine work myself except for turning down the ballscrew ends.
I have 5/8" ballscrews pushing around the 3 axis on THK SSR 20 rails.
The steppers are about 450oz.
The drives are Geckos and the breakout board is SoundLogic from Bob Cambell.
The computer is a ASUS 2.2 with 512 ram....
I have 9 precision intricately (sp?) safe proxs...3 on each axis...
I used Igus wire tracks...throughout.
The power supply is 48vdc MR25 TelCom battery charger with its own cooling setup...its mounted behind the Hoffman enclosure with the 1 KVA control power transformer.
There's alot more but you get the gist of it...
Chuck
