Whitetail Obsession Crib Board
Postby jay pieper » Sat Aug 17, 2019 9:37 pm
Been working with solid surface material lately, Corian in this case. Deer hunting in November in Wisconsin
is a big deal. I decided to use the v-carve inlay methods to achieve what I wanted. Here I decided to use 4
differn't colors of corian to be inlayed into the cover of the cribbage board. The cover starts out as a 8x8 inch
piece that has a vcarve pocket of .2inch pocket with advanced toolpath and 1/8 inch endmill. The text, deer,
grass and log are put in differn't layers and machined in differn't colors at a start depth of .1 and a flat depth of
.1 inchs. What worked for me was to mirror the deer for instance, machine the the piece and glue into the cover blank
after it was dried cut it flush to the cover with a bandsaw, this will allow you room to glue the next color in
cover. Repeated the process for all the colors in the cover. Went back to the CNC put the cover back in the
alignment jig and ran a flatting toolpath with a .25 endmill until the cover blank was flat and flush and then
alot of wet sanding and buffing. I hope the post made sense, I tend to get ahead of myself.
jay pieper
Model of CNC Machine: laguna swift 4x4
Re: Whitetail Obsession Crib Board
Postby Savannahdan » Sat Aug 17, 2019 9:42 pm
Excellent! Thank you for sharing the photos and describing how you made it.
Savannahdan
Postby scottp55 » Sat Aug 17, 2019 10:33 pm
LIKING IT! :D
Good Job!!
scottp55
Postby gkas » Sat Aug 17, 2019 10:34 pm
Nice board, and the inlays look great. No room for a single screwup....
gkas
Postby tomgardiner » Sun Aug 18, 2019 11:25 am
Did you resaw the lid and base to achieve a good grain match between the two? Very nice work.
tomgardiner
Postby mtylerfl » Sun Aug 18, 2019 1:01 pm
Wow! What a great job (and a lot of planning) you did, Jay! Extraordinary and beautiful!
Postby jay pieper » Sun Aug 18, 2019 3:40 pm
Tom to answer your question about resawing:
1. The solid surface material I used (Corian) is .5 inchs thick so I use 2 pieces laminated together
to make the base of the cribbage board. This is than surfaced on both sides to .8 inches thick.
2. The cover is selected from another piece of corian that you thinks looks good with the base you
made earlier.
3. The only resawing I do is between the differn't colors that are inlayed in the cover for the
images that are used. And really the use of the band saw is to cut the mirrored image free
of the cover so you can add the next color(image) to the cover.
jay pieper
Postby Phil » Sun Aug 18, 2019 3:44 pm
Very nice, well done.
Phil
Phil
Return to VCarve - Gallery
