"Stacked Text" Technique
Postby mezalick » Tue Aug 13, 2019 9:32 am
I happen to be a fan of the "Stacked Text" Technique in the Vectric software.
So I decided to push my limits with what can be possible...
This is a three layer "Stacked" design I've had on the drawing board for many years......
I call it "The Gears of My Heart"........14" x 14" x 1" HDU.
I know this would have been easier using Aspire but I wanted to see what could be accomplished in VCarve..
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
mezalick
Re: "Stacked Text" Technique
Postby Savannahdan » Tue Aug 13, 2019 11:46 am
Looks like you got the gears right off of the factory floor. Great job. What bit or bits did you use? Thank you for sharing.
Savannahdan
Postby highpockets » Tue Aug 13, 2019 12:15 pm
Beautiful work Michael! I really like the paint job.
I'd say that's pushing the limits of "Stacked Text".
Thanks for sharing.....
Postby mtylerfl » Tue Aug 13, 2019 12:34 pm
Yessah!! Fantastic work, Michael! This is a great example of creativity using the Vectric VCarve software to produce artworks such as this.
This will be a nice addition (and inspiration) for attendees of your Vectric Classes you conduct, too!
carvebuddy.com
Postby scottp55 » Tue Aug 13, 2019 12:54 pm
WOW!
Pushing the limits AND excellent finish work! :)
IF I had an SO....I'd get Brownie Points for naming it "My Heart is Geared Towards You" :)
Beautiful Piece Michael!! :D
GMH
Postby Phil » Tue Aug 13, 2019 1:33 pm
Awesome, amazing, fantastic, creative.
I
it.
Phil
Postby gkas » Tue Aug 13, 2019 8:04 pm
FANTASTIC job.....
gkas
Postby ezurick » Wed Aug 14, 2019 11:08 am
Ummm. for us newbies. You used a stacked text technique on gears. But are they all just one file/project? It looks like you actually cutout little gears and attached them to the item. Could you explain this a little more for us new folks please?
~ Ed
ezurick
Postby sharkcutup » Wed Aug 14, 2019 11:51 am
I believe ezurick's project is all one project file. I have performed the same type operation on several projects of my own.
This project for example is originally individual items cut and glued together. I choose to attempt to design and carve it as one piece (3/4" thick pine board face are of birdhouse) with success! Carved using layers for each level (certain depths) to achieve desired results.
Great job on that gear project, Michael!!! And I second the renaming of the project as stated by Scott!
Sharkcutup
Facebook: Hogan's CNC Crafts
V-Carve Pro 9.519
sharkcutup
Postby mezalick » Wed Aug 14, 2019 9:31 pm
ezurick wrote:Ummm. for us newbies. You used a stacked text technique on gears. But are they all just one file/project? It looks like you actually cutout little gears and attached them to the item. Could you explain this a little more for us new folks please?
Are you familiar with the Stacked Text Technique ??
Like in the video..
https://www.youtube.com/watch?v=s7gyAcYfX6w
Same process..just cutting down each layer to "reveal" the new layer of gears.
Michael
Michael Mezalick
mm@mezalick.com
mezalick
Postby mezalick » Wed Aug 14, 2019 9:32 pm
Thanks for the comments...
It was a real brain twister...
Michael
Michael Mezalick
mm@mezalick.com
mezalick
Postby Holzarbeiter » Thu Sep 26, 2019 1:46 pm
That is an awesome piece of work, Michael.
Joe
I have a chip on my shoulder....several more in my hair and lots more all over my shop floor.
Holzarbeiter
Model of CNC Machine: Camaster Stinger SR24
Return to VCarve - Gallery
