"Stacked Text" Technique
- mezalick
I happen to be a fan of the "Stacked Text" Technique in the Vectric software.
So I decided to push my limits with what can be possible...
This is a three layer "Stacked" design I've had on the drawing board for many years......
I call it "The Gears of My Heart"........14" x 14" x 1" HDU.
I know this would have been easier using Aspire but I wanted to see what could be accomplished in VCarve..
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Re: "Stacked Text" Technique
Looks like you got the gears right off of the factory floor. Great job. What bit or bits did you use? Thank you for sharing.
- highpockets
Beautiful work Michael! I really like the paint job.
I'd say that's pushing the limits of "Stacked Text".
Thanks for sharing.....
- mtylerfl
Yessah!! Fantastic work, Michael! This is a great example of creativity using the Vectric VCarve software to produce artworks such as this.
This will be a nice addition (and inspiration) for attendees of your Vectric Classes you conduct, too!
- scottp55
WOW!
Pushing the limits AND excellent finish work!
IF I had an SO....I'd get Brownie Points for naming it "My Heart is Geared Towards You"
Beautiful Piece Michael!!
R.N.
R.N.
Awesome, amazing, fantastic, creative.
I it.
I it.
- gkas
FANTASTIC job.....
Ummm. for us newbies. You used a stacked text technique on gears. But are they all just one file/project? It looks like you actually cutout little gears and attached them to the item. Could you explain this a little more for us new folks please?
- sharkcutup
ezurick Wrote:
This project for example is originally individual items cut and glued together. I choose to attempt to design and carve it as one piece (3/4" thick pine board face are of birdhouse) with success! Carved using layers for each level (certain depths) to achieve desired results.
Great job on that gear project, Michael!!! And I second the renaming of the project as stated by Scott!
Sharkcutup
I believe ezurick's project is all one project file. I have performed the same type operation on several projects of my own.Ummm. for us newbies. You used a stacked text technique on gears. But are they all just one file/project? It looks like you actually cutout little gears and attached them to the item. Could you explain this a little more for us new folks please?
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- mezalick
Are you familiar with the Stacked Text Technique ??ezurick wrote:Ummm. for us newbies. You used a stacked text technique on gears. But are they all just one file/project? It looks like you actually cutout little gears and attached them to the item. Could you explain this a little more for us new folks please?
Like in the video..
Same process..just cutting down each layer to "reveal" the new layer of gears.
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- mezalick
Thanks for the comments...
It was a real brain twister...
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- Model of CNC Machine: Camaster Stinger SR24
That is an awesome piece of work, Michael.
Joe
