My latest Earth Wind & Fire panel
Re: My latest Earth Wind & Fire panel
Postby Rcnewcomb » Mon Jul 08, 2019 3:24 am
I wonder if I would need a different bit to carve the Corafoam ?
Foam is easier to carve than wood. I'll let the sign guys respond regarding feeds and speeds since I only cut small pieces of foam board.
If you need more practice material at a lower price you can use the pink or blue foam boards for the big box stores such as Home Depot. It is available in thicknesses up to 2". ->Link
Postby adze_cnc » Tue Jul 09, 2019 5:44 pm
A few points on cutting EPS foam to add to Randall's post.
There is a FOAMULAR "green" version which doesn't cut well at all. The surface feels brittle. It really tears out when cut.
Perhaps not from a big-box store but you can get 4" thick EPS (see image).
Onsrud (there are other cutter manufacturers) makes a bit that is great for cutting EPS. https://www.onsrud.com/Products/52554.asp It evacuates "chips" exceptionally.
When 3D cutting, static builds up. Ground yourself before touching the final object or you'll look like you were dumped in a blue or pink snow-drift.
Steven
4" bowl mould for ceramic slip-casting
adze_cnc
Postby Rcnewcomb » Tue Jul 09, 2019 8:08 pm
Wiping everything with a dryer sheet helps with static, but pink dust does seem to collect everywhere.
Postby TReischl » Wed Jul 10, 2019 1:18 am
A couple of years ago I did a large panel with 2 inch foam. Two bags of "chips". Put it out for garbage a few days later.
I just happened to be looking when the G man grabbed the bag, shook it a few times and then turned it upside down to shake it into the truck. Why he did that I will never know. . . .there was a breeze. . . . . I called the Head Shed and they sent out a cleanup crew.
Previous
Return to VCarve - Gallery
Users browsing this forum: No registered users and 14 guests
