Having problems with stl file
Postby d6gwood » Sat Apr 20, 2019 4:15 pm
Can you import stl files in the modeling tab? If so how because all I get is a out of memory tab. My ram is at 4 gb and I have plenty of memory on my hard drive. Can someone help me figure this out please?
Dan
d6gwood
Model of CNC Machine: x-carve
Re: Having problems with stl file
Postby ger21 » Sat Apr 20, 2019 4:32 pm
You may indeed be running out of memory.
A hard drive is not "memory".
And 4Gb of memory is not a lot on a Windows 10 PC.
How big is the .stl file?
Go to File > Import Component / 3D model
ger21
Postby adze_cnc » Tue Apr 23, 2019 6:18 pm
I suppose out of memory could be possible depending on the mesh face count of your STL file and your set job size resolution (e.g. the 50x slower one).
For example I downloaded an "espresso cup" model from Thingiverse that measures: 65.061 by 85.595 by 50.046 millimeters. Despite its small size it contains 59,000+ faces.
Having said all this, I just tried importing a 1,293,000 triangle STL file at "50x slower" and VCarve laughed at me. Mind you I do have 32gb machine.
adze_cnc
Return to VCarve - Gallery
