steampunk desklamp
steampunk desklamp
Postby frank taylor » Mon Apr 08, 2019 2:31 am
made from 6mm and 3mm mdf fully up its 800mm high down 600mm frames painted copper metal and the gears gold has an Edison bulb and a Frankenstein on off switch
frank taylor
Model of CNC Machine: bravoprodigy be3030
Re: steampunk desklamp
Postby mtylerfl » Mon Apr 08, 2019 12:17 pm
Another great project, Frank! I love the industrial-look and the Frankenstein switch!
Thanks for showing us the pics!
Postby rtibbs2018 » Mon Apr 08, 2019 12:37 pm
Very. nice work! It’s on my ever growing list of projects :D
rtibbs2018
Model of CNC Machine: Shopbot desktop
Postby Phil » Mon Apr 08, 2019 1:15 pm
Very cool. I think you could sell the plans for that design. I'm sure you have a fair amount of time invested.
Phil :)
Phil
Postby SteveNelson46 » Mon Apr 08, 2019 4:45 pm
Really cool. It should be a great conversation piece.
SteveNelson46
Postby GEdward » Mon Apr 08, 2019 6:56 pm
Cool indeed! I'm with Phil in thinking you could probably sell the plans for it. It's hard enough to make progress on the bucket list and then I have to add one more.
What program did you use to generate the gears?
GEdward
Model of CNC Machine: Romaxx WD-1
Postby frank taylor » Tue Apr 09, 2019 12:38 am
thanks men this design I bought of ebay steampunk steel lamp dfx. format to be plasma cut from steel and the gears welded to the axles I added 1/8th slots to the gears and drilled 1/8"dia. pin holes in the bolts to get the gears to rotate also added 1/6th fillets to all of the sharp corners all pieces were cut using a 1/6th dia. straight flute end mill
so go for it men regards frank
frank taylor
Postby rtibbs2018 » Tue Apr 09, 2019 11:50 am
http://frednelsonfabrication.com/steel% ... 20assy.htm
Plans available from Fred Nelson Fabrication
Not intending to hyjack the thread however, there seems to be an interest in this design
rtibbs2018
Return to VCarve - Gallery
Users browsing this forum: 01f4irider and 6 guests
