Got me a laser, anyone know where to buy sharks?
Postby Mobius » Sat Mar 30, 2019 2:12 am
Finally pulled the trigger and added a laser to my CNC. I'm loving it so far, and it's opened up a whole new realm of possibilities.
Just completed my first official job with it, using customer supplied driftwood. And of course V-Carve Pro was used to draw the vectors, and to generate the G-code using a modified PP.
The top piece had some crazy undulations. The original plan was to pocket a flat spot first, but turns out I didn't need to.
Had to hit up the YouTube University and learn how to tie eyelets in rope. 3 different 'firsts' in this project.
Connor Bredin
www.distinctive-concepts.ca
Mobius
Re: Got me a laser, anyone know where to buy sharks?
Postby scottp55 » Sat Mar 30, 2019 2:22 am
Way to go Connor!! :D
LOVING the overall effect!!
Kudos!
GMH
Postby highpockets » Sat Mar 30, 2019 3:02 am
WOW!
Great work. Really like the look of the finished project. Gives me some ideas for friends of mine that live in Kill Devil Hill.
Some day I'll be home long enough to install my laser.
Thanks for sharing Connor.
Postby Leo » Sat Mar 30, 2019 1:14 pm
That is REALLY cool.
What a fantastic idea.
www.leosworkshop.com
Leo
Postby Mobius » Sat Mar 30, 2019 3:48 pm
Thanks for the positive comments guys. I had a blast making this one!
Connor Bredin
Mobius
Postby GEdward » Sat Mar 30, 2019 6:53 pm
Great job! Well executed. I have two questions. First, you mention that you didn't have to machine a flat area for the top piece so I have to wonder how much can you get away with within the focal range of the laser? It looks to me that you had at least .200" of deviation overall. And second, I assume this will be used outdoors so what will you use to preserve the finished product from the elements?
OK, three questions, what brand and power is you laser?
GEdward
Model of CNC Machine: Romaxx WD-1
Postby Mobius » Sat Mar 30, 2019 7:45 pm
GEdward wrote:Great job! Well executed. I have two questions. First, you mention that you didn't have to machine a flat area for the top piece so I have to wonder how much can you get away with within the focal range of the laser? It looks to me that you had at least .200" of deviation overall. And second, I assume this will be used outdoors so what will you use to preserve the finished product from the elements?
1. I have a 3 element lens in the laser, which has a long focal length and low divergence, at the expense of only being 70% efficient. It has a 0.1mm (0.004") focused point, which coupled with low divergence, meant that with the relatively large detail it was able to maintain enough focus to do the engraving without distorting the text/image.
It was actually over .5" of deviation. I set the zero in the middle of that, so it only had a .25" deviation in either Z direction.
2. The whole project was sprayed with several coats of General Finishes Exterior 450. You can see in the last picture it's glossier than the previous ones.
3. The laser is from Endurance lasers. It's their 10W laser (6W diode, overpowered to 10W with additional cooling). I've actually modified/customized it a bit to better suit my application and am running it at 12W. For this engraving it was running at 20% output @ 60 IPM.
Connor Bredin
Mobius
Postby martin54 » Thu Apr 04, 2019 2:48 pm
What a fantastic piece of work, or should I say art? Thanks for sharing. :lol:
John +1 lol :lol: :lol:
Return to VCarve - Gallery
Users browsing this forum: No registered users and 12 guests
