nine pieces of mdf 400x400x3mm glued together a picture I found on the internet traced the top layer used the offset tool layer by layer then the rotate tool all cut with 1/8 endmill
Looks very interesting. If truly a maze then could you drop a marble in there and cover the top with some acrylic so flipping and rotating you could work the marble through the maze from visible pocket to pocket?
