Any ideas ?
Any ideas ?
Postby woody53 » Sun Jan 06, 2019 11:48 pm
Did a V Carve on a bamboo pizza paddle and need to color the V Carve with something. Oil would be ok, but not sure it would show up very well. I don't want to start something then find it wont work.
Thanks guys.
Dave
woody53
Model of CNC Machine: Probotix Meteor 25 x 50
Re: Any ideas ?
Postby Rcnewcomb » Mon Jan 07, 2019 12:09 am
Are these decorative or does the finish need to be food-safe?
Re: Any ideas ?
Postby woody53 » Mon Jan 07, 2019 2:25 am
They need to be food safe Randall, that's why I'm stuck and asking.
Dave
woody53
Re: Any ideas ?
Postby lsvien » Mon Jan 07, 2019 2:49 am
General Finishes makes a salad bowl finish that is non-toxic when cured. I use it when working with items that are going to come into contact with food. If you are wanting to use the paint and sand method I would still finish the wood with the salad bowl finish first. Bamboo is pretty porous and you probably will get some paint bleed up the pores if you don't seal the v carve first. If it was my project and I wanted color I would seal with a couple coats of salad bowl finish, paint with an acrylic hobbyist paint, sand any mistakes outside the lines, then a couple more coats of salad bowl finish. Personally I think just a couple coats of a non-toxic finish should give you enough contrast. If you use this method you still can make that call after the first two coats of salad bowl finish.
lsvien
Model of CNC Machine: Shark
Re: Any ideas ?
Postby woody53 » Mon Jan 07, 2019 2:54 am
I will give salad bowl finish a try. Thanks for the suggestion.
Dave
woody53
Re: Any ideas ?
Postby Rcnewcomb » Mon Jan 07, 2019 3:02 am
You can make food-safe dyes using coffee or tea. ->e-how article
Re: Any ideas ?
Postby Tailmaker » Mon Jan 07, 2019 3:09 am
You could torch the carving (lightly) with a narrow flame and then sand the flat surface over before finishing with oil.
That said, having a carving on a pizza paddle dusted with flour (to smoothly slide off the limp dough) will not exactly improve usability.
The flour and overflow tomato sauce will get stuck in the carving or the dough may catch. I usually have to brush off my (uncarved) pizza paddle under running water after use.
A vcarve inlay might be better.
Tailmaker
Re: Any ideas ?
Postby Tailmaker » Mon Jan 07, 2019 3:48 am
lsvien wrote:..... Bamboo is pretty porous and you probably will get some paint bleed up the pores if you don't seal the v carve first.....
Can not really confirm that. While I used bamboo plywood mostly for more practical things like furniture, I tried a few experimental v-carvings just to see how it came out. The dragon below is in natural color vertical set bamboo plywood (your paddle is similar but horizontally set strips) with simple black spray paint filling and the other one is in marbled compressed bamboo (floor panels) with gold spray paint. I did not see much bleeding if any in either experiment. IIRC I did not seal the surfaces before filling the carving.
Tailmaker
Re: Any ideas ?
Postby rscrawford » Mon Jan 07, 2019 5:05 am
Most finishes are food safe once they are fully polymerized or 'dry'.
If the bamboo was prefinished before you carved into it, you could use an aniline dye to colour the v-carve, then apply an oil finish. Pure tung oil is completely food safe even before it polymerizes (but does take a long time to polymerize, at least a week per coat).
Russell Crawford
rscrawford
Model of CNC Machine: CAMaster Cobra 408 ATC with recoil
Re: Any ideas ?
Postby Savannahdan » Mon Jan 07, 2019 12:25 pm
One of the things you will have to consider is cleaning the peel especially with the carving in it. I would go with pure tung oil which doesn't have additives in it and can provide good protection including some water protection. I make some pieces for a microbrewery to hold glasses of their various brews and they have to put their boards in a dishwasher. They recoat them with pure tung oil after about 3 washings. But their boards go through a much tougher use than yours would unless you are making those for a pizza shop.
Savannahdan
Re: Any ideas ?
Postby SteveNelson46 » Mon Jan 07, 2019 3:33 pm
For durability, there isn't any finish that is as good as polyurethane. Like Russel stated, after it is polymerized most finishes are food safe.
I made some "flight trays" awhile back and used polyurethane for a finish. However, they don't put them in a dishwasher and I wouldn't recommend anything made out of wood to be placed in one.
SteveNelson46
Re: Any ideas ?
Postby woody53 » Mon Jan 07, 2019 7:38 pm
Thanks all. I decided to do bowl oil and it showed up great. Always get the right answers here. Thank you. It is for a pizza shop, and I figure they could always use the back side and hang the front side out.
Dave
woody53
Return to VCarve - Gallery
Users browsing this forum: ezurick and 5 guests
