Page 1 of 2
Wedding sign
Posted: Fri Dec 28, 2018 2:59 am
by wb9tpg
Made this as a gift for a friends wedding next January. Modeled it similar to one I saw on Facebook.
Re: Wedding sign
Posted: Fri Dec 28, 2018 3:21 am
by meflick
That looks great and I am sure your friends will be thrilled with the gift. Thanks for showing.
Re: Wedding sign
Posted: Fri Dec 28, 2018 3:36 am
by mtylerfl
Wow! That is nice!
Re: Wedding sign
Posted: Fri Dec 28, 2018 5:46 am
by mark-s
Very Nice.
mark-s
Re: Wedding sign
Posted: Fri Dec 28, 2018 1:31 pm
by scottp55
Beautiful job!
Well Done!!
Re: Wedding sign
Posted: Fri Dec 28, 2018 4:20 pm
by lsvien
Very nice. Did you mask then cut then paint or did you cut then paint then sand? What degree v-bit did you use?
Re: Wedding sign
Posted: Fri Dec 28, 2018 6:35 pm
by Royrufus
Very nice job. Beautiful layout and nice clean carving and painting.
Re: Wedding sign
Posted: Fri Dec 28, 2018 7:06 pm
by wb9tpg
Hand paint with acrylic and wipe off the rest with a damp rag. The entire surface had several layers of Shellac before I painted.
60 degree Whiteside V-Bit. The font is Edwardian Script with Bold setting on. The Block Letter was originally Goudy.
The most difficult part was issues with the Vectors. Both those fonts have tons of errors and overlaps. You must "Convert to Curves" all the fonts and then fix the errors, adjust the spacing manually (for Edwardian Script) and then Weld the characters together. Then "Check Vectors" 10 million times and fix the errors.
I've a template file I'll upload that has the entire Goudy Alphabet already converted and Fixed with each letter on its own layer. The template still needs some finishing touches.
I wish a Gadget allowed me to replace the contents of a Text Box. That would allow me to build a gadget to automate some of the process.
Enjoy.
Re: Wedding sign
Posted: Sat Dec 29, 2018 12:08 pm
by LittleGreyMan
Hello,
I found the Goudy alphabet as SVG here:
https://openclipart.org/collection/coll ... oran/10842
I just checked one svg file. No import problem with Aspire 9.5 trial, but the vector validator found 20 overlaps and 4 intersections.
These files don't look bad, but need fixing some issues too.
Re: Wedding sign
Posted: Sat Dec 29, 2018 1:20 pm
by wb9tpg
The file I uploaded has the entire Goudy alphabet fixed and each letter on a separate layer. Just use the layer you need.
Re: Wedding sign
Posted: Sat Dec 29, 2018 2:56 pm
by sparky957
Thank you for the file.
Art
Re: Wedding sign
Posted: Sat Dec 29, 2018 4:50 pm
by LittleGreyMan
wb9tpg wrote:The file I uploaded has the entire Goudy alphabet fixed and each letter on a separate layer. Just use the layer you need.
Sorry, I read too quickly your post and just noticed "still needs some finishing touches". But this was for the template and not for the letters which are fixed.
Thanks for the file!
Re: Wedding sign
Posted: Sat Dec 29, 2018 5:53 pm
by martin54
Re: Wedding sign
Posted: Sun Dec 30, 2018 1:28 am
by RobertD
wb9tpg
Great Work really like the design and finish. A very personal gift. One question is the floral block and letter at the left part of the template or is it added in from the clipart library??
Bob
Re: Wedding sign
Posted: Sun Dec 30, 2018 1:49 am
by wb9tpg
RobertD wrote:wb9tpg
Bob
It's part of the characters in that font.
