Puzzle Pieces
Puzzle Pieces
Postby Mobius » Sat Jul 07, 2018 12:09 am
A client asked if I could make and engrave some tiny puzzle pieces (1.2" x 0.75" x 0.625"). I cut these two out as a test, and engraved my kid's names on them. Right one is Cherry, left is Mahogany with one coat of Danish oil.
Engraving is 0.09" - 0.11" tall, and came out a little cloudy. Wish I had a laser to see if that would work better.
Anyways, I'll probably make a necklace for my wife out of these 'test' pieces.
Connor Bredin
www.distinctive-concepts.ca
Mobius
Re: Puzzle Pieces
Postby Mobius » Sun Jul 15, 2018 7:40 pm
Client liked them so I cut a bunch. No engraving.
Put a few of the leftovers together and put some epoxy on one side (with a little gold in it for sparkle) to hold it together. I'll probably engrave something on the other side and epoxy that as well.
Connor Bredin
Mobius
Re: Puzzle Pieces
Postby ThomasScott » Sun Jul 15, 2018 9:34 pm
Mobius, Those came out great. I 've been trying to cut some examples since I saw your
first post with no luck. I tried some online piece generators that seemed to work well as
far as generating the piece vectors. I tested a 4 piece group, separated them into individual
parts and profile cut them on the outside, but they don't fit, close, but I'm missing something .
Can you share how to cut these as you seem to have a perfect fit!
Thanks, Scott
ThomasScott
Model of CNC Machine: Probotix Nebula
Re: Puzzle Pieces
Postby Mobius » Mon Jul 16, 2018 4:33 am
Hi Scott,
I found a puzzle piece shape I liked through an image search and vectorized it using Inkscape. I then imported the vector into V-Carve and copied it a few times to test virtual fitment.
My first test cuts didn't fit either, the vectors just didn't quite match. I ended up rebuilding the piece, starting with the 'female' sides. I offset the 'female' sides outwards 0.001", which gave me new 'knob' or 'male' sides which matched the 'female' sections closely and were slightly smaller in order to fit together.
I then took those new 'male' sides and replaced the 'male' sides on the original vector. After a little node editing and copy pasta, they now all appeared to fit together in any orientation. And so it was for the physical pieces as well.
I've attached a .dxf of my puzzle piece for your convenience.
Puzzle_Piece.dxf
(52.75 KiB) Downloaded 170 times
Connor
Connor Bredin
Mobius
Re: Puzzle Pieces
Postby ThomasScott » Wed Jul 18, 2018 12:01 am
Connor, Thank you for the info and the example file, very helpful. Didn't think it was a
quick and easy solution, i will have to play around with node editing the vectors I have
and testing them out. This would make an awesome gadget if someone smarter than I
could figure out a mathematical solution to this !
again thanks for the info
Scott
ThomasScott
Re: Puzzle Pieces
Postby Mobius » Sat Jul 21, 2018 10:57 pm
Just put a little clip regarding these on YouTube if anyone wants to check it out:
https://youtu.be/6jZlP6KISus
Connor Bredin
Mobius
Re: Puzzle Pieces
Postby mtylerfl » Sat Jul 21, 2018 11:50 pm
Cool video, Connor! Thank you!
carvebuddy.com
Re: Puzzle Pieces
Postby Xxray » Sun Jul 22, 2018 6:00 am
So, what bit did you use to profile them ?
Xxray
Re: Puzzle Pieces
Postby Mobius » Sun Jul 22, 2018 4:52 pm
Xxray wrote:So, what bit did you use to profile them ?
A 1/16" 2 flute downcut bit from ToolsToday.
Connor Bredin
Mobius
Return to VCarve - Gallery
Users browsing this forum: Google [Bot], The Carpenter & co and 11 guests
