I milled an aluminum mold for Injektion fishfor fishing for a friend. Aluminum 5083, 3mm milling cutter and 2mm radius cutter
Aluminium Fishing Mold
- mtylerfl
Re: Aluminium Fishing Mold
Very cool!
- Model of CNC Machine: Axiom A8 Pro+
Flyfish wrote: 3mm milling cutter and 2mm radius cutter
Looks clean...a 3mm EM and a 2mm BN? That must have taken forever...mind sharing some details of the cut?
I'm just starting to experiment with aluminum and looking for all the hints/help I can get...Thanks
- Model of CNC Machine: Stepcraft 420 and Optimum BF20 CNC
Hi, so I drive with the X and Y axis at 720 mm / min and with the Z axis at 520 mm / min. Speed is 15000 1 / min. I use the aluminum 5083. Mold milling time was 8 hours for both halves.
Thanks for that...the info gives me a good place to start and your project gives me a good example of the quality I should be shooting for...Flyfish wrote:Hi, so I drive with the X and Y axis at 720 mm / min and with the Z axis at 520 mm / min. Speed is 15000 1 / min. I use the aluminum 5083. Mold milling time was 8 hours for both halves.
