Page 1 of 1
Cutting Board
Posted: Wed Feb 28, 2018 12:16 am
by rgerding
Nice gift idea and easy to make and personalize. Juice groove is a bonus.
Re: Cutting Board
Posted: Wed Feb 28, 2018 12:23 am
by Makingtoothpicks
Very nice. I need to make a cutting board soon.
Don
Re: Cutting Board
Posted: Wed Feb 28, 2018 3:15 am
by dwilli9013
Nice I also need to try the cutting board arena out. Thanks for sharing.
Re: Cutting Board
Posted: Wed Feb 28, 2018 8:45 pm
by mfirlott
Nice piece of work. I like how the side area holds a v-carve and the grain goes in a different direction. Looks real nice.
Re: Cutting Board
Posted: Thu Mar 01, 2018 7:05 pm
by JoeinWestMich
Nice idea but when you glue two cross grains on a cutting board like this it is likely to crack in this area.
Re: Cutting Board
Posted: Thu Mar 01, 2018 7:19 pm
by mtylerfl
That sure is a classy-looking cutting board! It's Beautiful!
Re: Cutting Board
Posted: Thu Mar 01, 2018 8:03 pm
by rgerding
To JoeinWestMich I realize gluing crossgrain can be a problem so I used my biscuit jointer and put biscuits in the joint. I also used TitebondIII which is water resistant in the joint. I've made these in the past and they're still holding together. Very good observation.
Ron
Re: Cutting Board
Posted: Mon Apr 16, 2018 12:13 pm
by Ben225
What type of wood do you recommend for cutting board and what finish are you using to make it food safe ?
Re: Cutting Board
Posted: Mon Apr 16, 2018 1:47 pm
by rgerding
Any hardwood is good for cutting boards except Oak which has a loose grain. I use maple, walnut and cherry. I've found Howard's butcher block conditioner to be a very good product for finishing cutting boards.
Re: Cutting Board
Posted: Fri Jun 29, 2018 12:28 am
by jeffhcarter
Do you remember the font for the lettering. I am looking for a similar font for some boards
Re: Cutting Board
Posted: Fri Jun 29, 2018 4:21 am
by potzmannwoodshop
rgerding wrote:Any hardwood is good for cutting boards except Oak which has a loose grain. I use maple, walnut and cherry. I've found Howard's butcher block conditioner to be a very good product for finishing cutting boards.
You can stop spending big $$$ on anything called butche block oil/conditioner. Go to your closest pharmacy, 2.99ish for 16oz of mineral oil. all you need, if you feel like you want a wax to make it shine a little more, go buy cheap beeswax. This will save you $$$$
<make and sell couple of hundred dollars of boards a month
Re: Cutting Board
Posted: Fri Jun 29, 2018 9:00 am
by RebeccaJ
Very Nice! I bet you have friends and family lined up asking you to make them one
Thank you for sharing this along with your tips!
