Cutting Board
Cutting Board
Postby rgerding » Wed Feb 28, 2018 12:16 am
Nice gift idea and easy to make and personalize. Juice groove is a bonus.
rgerding
Model of CNC Machine: Iconic 2015
Re: Cutting Board
Postby Makingtoothpicks » Wed Feb 28, 2018 12:23 am
Very nice. I need to make a cutting board soon.
Don
Makingtoothpicks
Model of CNC Machine: Cncrouterparts CPR2448
Re: Cutting Board
Postby dwilli9013 » Wed Feb 28, 2018 3:15 am
Nice I also need to try the cutting board arena out. Thanks for sharing.
D-Dub
Dwayne
Dwilli
dwilli9013
Re: Cutting Board
Postby mfirlott » Wed Feb 28, 2018 8:45 pm
Nice piece of work. I like how the side area holds a v-carve and the grain goes in a different direction. Looks real nice.
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
Epilog 45watt Helix Laser
mfirlott
Re: Cutting Board
Postby JoeinWestMich » Thu Mar 01, 2018 7:05 pm
Nice idea but when you glue two cross grains on a cutting board like this it is likely to crack in this area.
JoeinWestMich
Model of CNC Machine: ShopBot Buddy 48T PRS alpha HSD 2.2HP
Re: Cutting Board
Postby mtylerfl » Thu Mar 01, 2018 7:19 pm
That sure is a classy-looking cutting board! It's Beautiful!
carvebuddy.com
Re: Cutting Board
Postby rgerding » Thu Mar 01, 2018 8:03 pm
To JoeinWestMich I realize gluing crossgrain can be a problem so I used my biscuit jointer and put biscuits in the joint. I also used TitebondIII which is water resistant in the joint. I've made these in the past and they're still holding together. Very good observation.
Ron
rgerding
Re: Cutting Board
Postby Ben225 » Mon Apr 16, 2018 12:13 pm
What type of wood do you recommend for cutting board and what finish are you using to make it food safe ?
Ben225
Model of CNC Machine: openbuild
Re: Cutting Board
Postby rgerding » Mon Apr 16, 2018 1:47 pm
Any hardwood is good for cutting boards except Oak which has a loose grain. I use maple, walnut and cherry. I've found Howard's butcher block conditioner to be a very good product for finishing cutting boards.
rgerding
Re: Cutting Board
Postby jeffhcarter » Fri Jun 29, 2018 12:28 am
Do you remember the font for the lettering. I am looking for a similar font for some boards
jeffhcarter
Re: Cutting Board
Postby potzmannwoodshop » Fri Jun 29, 2018 4:21 am
rgerding wrote:Any hardwood is good for cutting boards except Oak which has a loose grain. I use maple, walnut and cherry. I've found Howard's butcher block conditioner to be a very good product for finishing cutting boards.
You can stop spending big $$$ on anything called butche block oil/conditioner. Go to your closest pharmacy, 2.99ish for 16oz of mineral oil. all you need, if you feel like you want a wax to make it shine a little more, go buy cheap beeswax. This will save you $$$$
<make and sell couple of hundred dollars of boards a month https://www.instagram.com/p/Bi747ilgjsd ... nnwoodshop
potzmannwoodshop
Model of CNC Machine: 2 SCM Routech Record 120s(1999, 2001)
Re: Cutting Board
Postby RebeccaJ » Fri Jun 29, 2018 9:00 am
Very Nice! I bet you have friends and family lined up asking you to make them one :P
Thank you for sharing this along with your tips!
Beki Jeremy
RebeccaJ
Model of CNC Machine: Various
Return to VCarve - Gallery
Users browsing this forum: ozymax and 4 guests
