Here's something my wife asked for. She does a lot of needlepoint. It's used to hold skeins of needlepoint thread. She was complaining the ones for sale only have 6-10 holes. That's not enough for a full project. ...and they charge $10-20.
This would be great for crafts sales. I made the holes 0.35 in diameter. As many holes as you want. Use about 0.25 wood. That should be a nice profit. Less than 2 minutes to cut. Batch 'em out. Vcarve needle/thread pic, initials, etc. Make different shapes. Use 'Copy Along Vectors' to make hole path around your shape.
Needlepoint Thread Organizer
Re: Needlepoint Thread Organizer
Well done. Thanks for sharing.
- highpockets
Thanks for sharing.
I'm going to make one for my wife also.
One suggestion, on the holes use a profile cut instead of a pocket it should go faster and you can use the Ramp - Spiral options which will save the end mill.
- gkas
I used the pocket so I wouldn't have to worry about chunks leftover. But, now that you mention it, a profile would cut the entire hole out because of the size of the bit. A new trick.
tnx
tnx
- dwilli9013
Nice job clean and functional. Is there no limit to what these CNC's can do. Thanks for sharing gives me ideas.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
