Help needed.
- Model of CNC Machine: Probotix Meteor 25 x 50
Help needed.
I am going to try and do some edge-lit acrylic and could use some help. Searched on here and saw a lot but my old brain still needs more. Xxray and Dwayne have done some awesome edge-lits and that's what I want to do. Thanks for the help.
Dave
Dave
- mezalick
Re: Help needed.
So, you need a little more.
Here's something different....
My Christmas center piece..
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Re: Help needed.
I have seen your works of perfection also Michael. I will keep looking and get all the info I can. Thanks.
Dave
Dave
Re: Help needed.
First try, came out Ok. See where I need to make a few adjustments.
- Makingtoothpicks
- Model of CNC Machine: Cncrouterparts CPR2448
Re: Help needed.
you are making LED acrylics the same way I do. Nothing wrong but not enough.
Square or rectangular. The ones that stand out and get the wow factor are the
ones that are outside the box. So I will be thinking about the next one I do and
see if I can get outside the box. Things like the lighting frame work , the shape
of the acrylic , use of colors , multi color and maybe incorporating no acrylic
items into the mix. Many of the really talented uses on this forum and others
are great re-purposes of many found objects and other things. So what am I
saying look at your next project and think outside the box. My problem is I am
not artistic and I know it. So I re-purpose ideas that others think of. I am a borrower
I saw a whisky bottle display that got me to thinking of a display for a bottle of Jameson
I have the label says Donald James Murphy and it is 12 year old after seeing the one in
the post I got an idea hope to start on it soon. Good luck and have fun
Don Murphy
Don Murphy
Re: Help needed.
You're right Don. This is my first attempt and like I said I need to fine tune the tool-path and bit settings, but it looks like a edgelit anyway. Will be thinking outside and I saw yours you were talking about.
Dave
Dave
- Makingtoothpicks
Re: Help needed.
I did forget to mention that your led came out nice. Looks like you may have not decided on a base
I try to keep the base simple if I am giving them away . I have not tried anything like the Santa
but who knows ?. AC/DC maybe a lighting bolt theme ?.
Don
Don
- Xxray
Re: Help needed.
Looks good to me, anything specific you need to know ?
They make LED controllers that dance to music, would look cool blasting out some AC/DC and watching the lights bounce to the beat.
Doug
- Model of CNC Machine: diy 4 X 4 CNC Router
Re: Help needed.
Made this as a display in my office at the shop.
RGB leds.
Acrylic cut on the cnc.
White Oak base cut on the cnc.
mark-s
RGB leds.
mark-s
- dwilli9013
Re: Help needed.
Uh Oh looks like Dave has the edgelit addiction starting. First run looks great. You will have a ton of fun with these. I know I do.
The attached is one I knocked out for a buddy last week. New base variation for me.
Keep up the good work and thanks for sharing.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- Model of CNC Machine: CRP Pro 4848 Custom Build
Re: Help needed.
Oh, that base is spot on! Nice work on the sign too.dwilli9013 wrote:Uh Oh looks like Dave has the edgelit addiction starting. First run looks great. You will have a ton of fun with these. I know I do.
Connor Bredin
www.distinctive-concepts.ca
Re: Help needed.
All of these are nice and helpful advice too...joe
Re: Help needed.
Dwayne, I saw a base like that and thought that would be cool. Doug, I Love the idea of lights rockin to AC-DC. Thank for the ideas and showing all your great work. Like AC-DC you guys ROCK !!!!!
- Xxray
Re: Help needed.
Nice, did the same thing a few years back, ended up giving this to a little girl and she was thrilled, still uses itdwilli9013 wrote:Uh Oh looks like Dave has the edgelit addiction starting. First run looks great. You will have a ton of fun with these. I know I do.
Doug
