"Birdcage" Hollow candlestand
llwood
Model of CNC Machine: Legacy Maverick
Post by llwood »
This is a design I'm affectionately calling the Birdcage candlestand because of the hollow globe in the center. The center post was cut using the wrapping gadget. I had to order extra long bits, because in order to contour the inside of the "legs", the bit had to reach all the way through the center in order to cut a fluting toolpath on the inside of the leg on the opposite side. It was designed with an odd number of legs so that an opening on one side would match the inside of the leg on the other side. The contour on the outside of the globe was cut using a moulding toolpath.
For the base and the cup, I created the shape using dome_dish_45 from the clip art, and projected a vcarve toolpath onto the 3D model. In the measure tool, the 3rd option is to "model a cross-section." I used this to generate a vector which was used to create a moulding toolpath. I cut the curve using a moulding toolpath instead of 3D toolpaths, in order to be faster and have the cuts conform to the shape of the object by having the bit move in a circular instead of a square pattern. HOWEVER, I could still project the vcarve toolpath onto the 3D model and it came out perfectly!
Just in time for Christmas!
Andy
Ash with statesman oak stain
English Walnut with clear finish
Bobtail Farm
Re: "Birdcage" Hollow candlestand
Post by Bobtail Farm »
Thanks for the mention of "model a cross-section". Exactly the feature I've been casting about for a project.
Fleming
Post by Fleming »
A beautiful and creative piece of work :D
Bob Jr
Model of CNC Machine: Axiom, Shark
Post by Bob Jr »
That is such a neat technique and project. I followed your description and reason for using the moulding tool with the 3D dish shapes through the moulding toolpath. But, I could not generate a moulding toolpath. I think I need a little more guidance at the moulding step.
Thank you,
Bob
"Be accurate."
W. Tell
GEdward
Model of CNC Machine: 24 X 36 3 Axis
Post by GEdward »
Great work from what appears to be a fertile imagination. It would make for a good youtube presentation/tutorial.
llwood
Post by llwood »
Bob Jr wrote:That is such a neat technique and project. I followed your description and reason for using the moulding tool with the 3D dish shapes through the moulding toolpath. But, I could not generate a moulding toolpath. I think I need a little more guidance at the moulding step. Bob
Bob, What sort of problem are you having generating a moulding toolpath? I was unable to upload my .crv file because it's too big, so instead I put it up on Google Drive. You can download it by clicking on the link below. The you can see the 3D profile generated and also the components of the moulding toolpath.
https://drive.google.com/open?id=16JayC ... 8pX9UkQGfc
One thing to know: In order to get the shape I wanted, the dome is actually deeper than the material. VCP complained about this, so I had to make the material size thicker in the file than the actual material size. this is because the top of the dome is outside the material. I added a comment about this in the notes. If you can let me know more specifically the problem you are having, I know we can figure it out.
And thanks everyone for the feedback,
Andy
Bob Jr
Post by Bob Jr »
Andy,
The world makes sense again. You used the inner circle as the drive rail, not the outer!
Thank you very much for your help.
Bob
"Be accurate."
W. Tell
sharkcutup
Post by sharkcutup »
AWESOME Detailed Carving!!!
That is a GREAT GIFT IDEA for that special honey-do master in anyones household!!!
Sharkcutup
V-Carve Pro 12.004
llwood
Post by llwood »
Bob Jr wrote:You used the inner circle as the drive rail, not the outer!
Yes, any time the drive rail is a CLOSED vector, the profile vector will always be applied to the outside of the drive rail (even reversing the vector doesn't change this), so the drive rail must be the inner circle.
If you really want to use the outer vector as the drive rail, the only way to do it is to cut the closed vector into 2 open vectors and have 2 moulding toolpaths, one for each of the 2 open vectors. When the drive rail vector is open, it can be cut on the inside.
RebeccaJ
Vectric Staff
Model of CNC Machine: Various
Post by RebeccaJ »
Oh wow - you've used a combination of techniques! Very inspiring!
Beki
Senior Application Engineer - Vectric Ltd.
mikeacg
Post by mikeacg »
Andy,
I was under the impression that Aspire wouldn't allow you to go deeper than 0,0 (the center of the cylinder). How did you manage to go inches beyond?
Mike :?
llwood
Post by llwood »
mikeacg wrote:I was under the impression that Aspire wouldn't allow you to go deeper than 0,0 (the center of the cylinder). How did you manage to go inches beyond?
Mike, I can't speak for Aspire because I've never used it. In VCarve Pro, I cut the post using the wrapping gadget, and the wrapping gadget basically creates a file that you work with as if it were flat, and then it is wrapped by using one of the postprocessors that maps Y to A. As with any other file, VCarve Pro will allow you to cut deeper than the material, it just shows a warning message when you calculate the toolpath. I've attached the screen capture of the warning message I get when regenerating the toolpaths. I ignore the warning message, because this is intended, and the bits go deeper than the turning center.
I've also uploaded the .crv file so anyone can see directly.
Cheers,
Andy
BCHC Post 5.crv
(595.5 KiB) Downloaded 173 times
mikeacg
Post by mikeacg »
Andy,
Gary Campbell called me last night and set me straight. I missed the pocket path step the first time through. I'm going to be playing with the idea over the holidays on my Sidewinder!
Mike
