I'm getting frustrated, so I thought I'd ask for some advice from the brains trust here...
I'm trying to make some Christmas Tree ornaments where the person's name remains and most of the surrounding wood has been cut away. I realise this shouldn't be overly difficult, but I've reached an intellectual impasse here (there's a less polite term I like to use, but basically, I'm stumped).
Does anyone have a simple explanation on how to do something like this? I'm using the latest version V Carve.
Any suggestions at all would be gratefully accepted.
David
Australia.
Christmas Tree "Name" Ornaments
- Model of CNC Machine: X Carve
- highpockets
Re: Christmas Tree "Name" Ornaments
You might look into using the "weld" and "clip" tools as well as node editing.
You need some way to combine the letters to the outside of the ornament, including parts of letters that are separate.
- FixitMike
You have to turn the text into curves before you can weld them together or add them to a base.
- highpockets
Thanks Mike, I forgot to mention that very important part.FixitMike wrote:You have to turn the text into curves before you can weld them together or add them to a base.
Many many thanks for those hints. I’ll have another try (and continue hunting through the manual).
You folk have a merry Christmas and I look forward to seeing some more creations.
Regards,
David.
Regards,
David.
- highpockets
David,
If you're still having problems after giving it another try, post your VCP file and everyone will help you out.....
