MIA Plaque
- Model of CNC Machine: Shark HD4
MIA Plaque
This is a plaque d did but would like some help on making it better. Some of the littering chipped out. Any help would be greatly appreciated.
- dwilli9013
Re: MIA Plaque
What is you material, tooling and speeds you are cutting at?
The more information you can provide for the great people on this forum the more answers you will receive.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
Re: MIA Plaque
Sorry I should have added the tool and speed. I used a Tapered Ball Nose - 6.2 Deg Tip 0.016, 0.25 inches at 12000 rpm feed rate of 40 ipm plunge rate of 10 ipm. The material I used was flame maple.
Re: MIA Plaque
First I see areas of the lettering that the bit was too large to get out. What might help is always cut with the grain. Right now you are cutting against it, which can cause tear out.
Bob
Bob
- metalworkz
Re: MIA Plaque
Hello,
You might want to look at this old thread about similar MIA/POW plaques done some time back that has some files attached that could possibly be used if you have not already done that. There are different variations of Vectric software used and files available for Cut2D on up to Aspire 3D models posted by James who actually began this post. Hope something here will help you out.
http://forum.vectric.com/viewtopic.php? ... OW+plaques
