Light switch dragon cover plate.
FixitMike
Post by FixitMike »
Light box cover - dragon.zip
(1.07 MiB) Downloaded 347 times
Re: Light switch dragon cover plate.
Post by highpockets »
Thanks for sharing Mike.
Tundraman
Model of CNC Machine: Techno Isel 3'x4' Gantry III
Post by Tundraman »
Mike,
Looks great! :)
It looks like solid surface material?
Is the fill paint or something else?
Thanks for the files, as well.
Scott
mezalick
Post by mezalick »
Very nice Mike,,,Very clean design.
Thanks for posting.
Michael
Michael Mezalick
mm@mezalick.com
FixitMike
Post by FixitMike »
Process:
3/8" Baltic birch plywood.
2 coats wipe on poly. Sand lightly
Carve back pocket
Carve front
Countersink switch screw holes. Mask 2 csk holes in unpainted area.
Fill design with black artists acrylic paint
Sand to remove excess paint.
Blow out sanding dust with compressed air.
Bandsaw and belt sand corners
3/16" roundover edges on table router.
2 coats of wipe on poly, sand lightly.
Glue regular switch cover in back pocket with medium instant glue.
Mike,
Not looking a gift horse in the mouth, but why is the "Back side pocket" offset to the right? I'm assuming that's for the switch plate. Shouldn't it be center on the two light switch holes?
FixitMike
Post by FixitMike »
The back side pocket is mirrored because you flip the board (side to side) to cut it. It is also cut a little oversize on the width so you don't have to be real precise when you flip the board.
Never mind, I figured it out, the switches are offset just a bit and the pocket is on the backside so it's showing in reverse mirror.
LOL!!! You answered while I was retracting my question....
subsea
Model of CNC Machine: Zenbot 2448
Post by subsea »
Mike, great looking dragon. Thanks for the file.
- Bill
woody53
Model of CNC Machine: Probotix Meteor 25 x 50
Post by woody53 »
Thanks for sharing, Mike. Gonna make a single switch for my S.O.'s grandson. He loves dragons. Great idea and thanks again. will post when I do it.
Dave
woody53
Post by woody53 »
Got it done, Thanks Mike.
bravesoul
Model of CNC Machine: ShopBot PRT ALPHA 48"x96"
Post by bravesoul »
Not sure why the original plate has to be fitted into this? Is it for safety reasons?
Joe
FixitMike
Post by FixitMike »
bravesoul wrote:Not sure why the original plate has to be fitted into this? Is it for safety reasons?
Joe
Yes. Electrical code requires that cover plates be non flammable. Also, it reduces the chances of the wood splitting if you tighten the screws too much.
