Amazing Grace Engraving
Postby W3LMR » Sat Jul 23, 2016 8:23 pm
This project started out as a very old 1" piece of mahogany 28" long & 13" high I ran a pocketed tool path but my end mill was a little dull. It scorched some of the wood. I wanted to make this old hymn look equally as old so I left some of the darken wood as a boarder. I found this project as a pdf file on a Google search. I really liked the older looking font complete with the page number of the this old hymn. The wood even has some beetle holes throughout.
W3LMR
Model of CNC Machine: Homebuilt/ 32" x 54"
Re: Amazing Grace Engraving
Postby mtylerfl » Sun Jul 24, 2016 1:04 pm
That came out great! What bit and feed/speed settings did you use for the notation and lyrics?
Postby W3LMR » Sun Jul 24, 2016 7:51 pm
Top
Thanks!! mtylerfl: The bit was a Vbit 60degree 1/2" I had the feed rate at 20" / minute but used the over ride on Mach3 and turned it down to about-12-14" per minute. It took about five hours to Vcarve. I been enjoying looking around for weathered wood and making the projects appear old.
W3LMR
Postby mtylerfl » Sun Jul 24, 2016 10:33 pm
Thank you for the info!!
Postby SnaykeByte » Wed Aug 24, 2016 4:24 am
I have searched and came up short. Could you please provide your source for the crv files for this wonderful piece ?
SnaykeByte
Model of CNC Machine: Shark Pro
Postby SnaykeByte » Sat Aug 27, 2016 5:07 am
Just a little bump
SnaykeByte
Postby martin54 » Sat Aug 27, 2016 11:33 am
What search terms are you using, not looked myself but try using PDF as well as Hymn title, also try vector, sometimes helps to weed out some of what isn't suitable. I also use the drop down menus to exclude some of the stuff I don't want.
Postby W3LMR » Sun Aug 28, 2016 7:34 pm
I used Google search Amazing Grace png files then changed that over to pdf files (was easier this way to work with) then over into crv files.
Hope this helps!
W3LMR
Postby W3LMR » Sun Aug 28, 2016 7:58 pm
I am working on my 3rd Amazing Grace Plaque. The one yesterday I gave to my mother in Lancaster PA. On hers I made a picture frame out of walnut and it really seemed to give the plaque a nice depth to it. She is bedridden and this is one of her favorite hymns. The first one went to my 87 year old father-in-law who has shown it to just about everyone at the nursing home! This one today is for my 73 year old neighbor. Most everyone who sees it-has asked me to make them one. I made a mistake in my first posting-the wood is Sapele -it is grown in Africa and looks a lot like Mahogany. The letter Z in Amazing Grace did not cut the depth like all the other letters in Amazing Grace. I used the Vcarve instead of the profile toolpath. Any help in getting my letter Z to cut at the same depth is very much appreciated!!
W3LMR
Postby martin54 » Sun Aug 28, 2016 8:43 pm
You have copied my post which was actually a reply to the post above mine from SnaykeByte, who is looking for it :lol: :lol:
As for your Z not carving properly it could be down to a problem with the vectors, the depth that a vcarve toolpath will cut is dependant on the width between vectors, if the vectors for that letter are a bit narrower than the rest it won't cut as deep, have you have taken this from a bitmap image & traced it ?
Zoom right in on the z & have a look at the vectors, you might find an odd node or two making it narrower than other letters, just use node editing to move them if that is the case :lol: :lol:
Postby Daniel S » Tue Aug 30, 2016 6:13 am
Your carving looks outstanding to me. I also have carved Amazing Grace for choir member of our church but found a different file to use. I found many different copies of the Hymn to chose from so this is the version I chose to use. My old Shark Pro is on its last legs and not very rigid and I get irregular cuts also. So the hunt for a new machine is on the way.
Daniel S
Postby W3LMR » Tue Aug 30, 2016 8:00 pm
Daniel S Your Amazing Grace looks very nice! I am sure they liked it.
W3LMR
Postby SnaykeByte » Thu Sep 01, 2016 2:24 am
Could you please elaborate on this somewhat?
SnaykeByte
Postby martin54 » Thu Sep 01, 2016 3:02 am
SnaykeByte wrote:I used Google search Amazing Grace png files then changed that over to pdf files (was easier this way to work with) then over into crv files.
Different people work in different ways, W3LMR (sorry don't know their name) preferred to work with PDF files.
On a google search they searched for amazing grace pdf, google would have given a lot of different images based on those search terms, look through them & download the one you would like to carve. Open the software, set up a new job, import the file you downloaded using the "import bitmap for tracing" tool. Trace the bitmap then either turn off the bitmap layer or delete it. You now have a set of vectors that you can carve.
Depending on how well the image traces you may have to do some node editing :lol: :lol:
Postby jjack9485 » Mon Oct 10, 2016 2:51 pm
is there a stl file available for this amazing grace engraving ?
jjack9485
Model of CNC Machine: shark hd3
Next
Return to VCarve - Gallery
Users browsing this forum: Google [Bot], maplestiltskin, RebeccaJ and 6 guests
