Family plaque
Family plaque
Postby dwwright » Tue Jul 12, 2016 3:19 pm
This is a plaque I did for my daughter's new apartment, used a pre-made plaque, but had to coat it with lacquer and wax the top before applying the paint mask as I've had the avery paint mask pull the finish off these plaques in the past.
Image Image
Vcarve File:
Family2.zip
Family Vcarve File
(1 MiB) Downloaded 1709 times
dwwright
Model of CNC Machine: JGRO
Re: Family plaque
Postby scottp55 » Tue Jul 12, 2016 6:14 pm
Thank you for that file!
NICE job!!
GMH
scottp55
Re: Family plaque
Postby subsea » Tue Jul 12, 2016 10:30 pm
Nice. Thanks for the file.
subsea
Model of CNC Machine: Zenbot 2448
Re: Family plaque
Postby sailfl » Wed Jul 13, 2016 12:12 am
Very nice. Well done! Thank you for sharing you work.
sailfl
Model of CNC Machine: MechMate
Re: Family plaque
Postby mpol0717 » Wed Jul 13, 2016 3:09 am
Nice job! What brand mask did you use and did you apply the lacquer, wax then the mask? How well does it stick to wax? I've attempted masking of lacquer before, but left some pretty nasty residue behind.
mpol0717
Model of CNC Machine: Openbuilds ox
Re: Family plaque
Postby dwwright » Wed Jul 13, 2016 4:50 am
Thanks guys and enjoy.
I did a couple of coats of lacquer and let them dry on the plaque, then applied a generous layer of the minwax paste wax. I hardly let it dry before laying over the Avery paint mask (sorry don't remember the product number, but it's pretty tacky).
I did the carving, then made sure the paint mask was pushed down and trimmed where it came loose, which wasn't much, then spray painted, let it dry overnight, then removed the paint mask.
Since there was some wax and I had a couple of areas that the mask still was loose or gone, the paint on the plaques finish scraped right off cleanly. I just did a quick buff of the left over wax to give it a satin finish.
dwwright
Re: Family plaque
Postby watsonswords » Sat Jul 16, 2016 5:17 pm
Nice design! Thanks for the file too!
Tom Watson www.signsinwood.com
watsonswords
Re: Family plaque
Postby BArnold » Sun Jul 17, 2016 7:05 pm
Very nice work!!! I'll have to try the wax trick.
Bill Arnold
VCarvePro, PhotoVCarve, SketchUp, UGS
Member of Mensa and NRA
BArnold
Model of CNC Machine: SO2/XCarve hybrid w/NEMA23 on all axes
Re: Family plaque
Postby mmatarella » Tue Jul 19, 2016 5:08 pm
Thanks for the wax idea! I will try that today. I just started using oramask spray stencil film, and it can be tough to remove from some finishes if not taken off in a short time. I've had to pull it while the sprayed paint was still wet which makes some problems. It holds up fairly well even in some fairly small detail areas.
mmatarella
Re: Family plaque
Postby dah79 » Sat Aug 06, 2016 2:32 pm
https://www.dropbox.com/s/bx7nzb69a9nek ... 9.jpg?dl=0
My rendition of this file on a wood slab. Thanks for the file!!
Dave
dah79
Model of CNC Machine: FLA Saturn 4x4
Re: Family plaque
Postby scottp55 » Sat Aug 06, 2016 3:42 pm
Came out Really Nice Dave :)
Was the wood a little wet? That cambrium layer tearout looks like partially air dried?
Playing with wet Walnut right now, so I know:)
GMH
scottp55
Re: Family plaque
Postby dah79 » Sat Aug 06, 2016 4:11 pm
Thanks Scott. Don't think the wood was wet, I think it was a combination of soft basswood and too fast carving speeds. Have never had real good luck with basswood but it is very plentiful here. Just picked up a few slabs at a wood carving festival last weekend.
Dave
Dave
dah79
Re: Family plaque
Postby DavidWestley » Tue Aug 09, 2016 11:03 am
Thanks from Australia for generously sharing the file.
Whilst I'm generally not a huge fan of homilies, this one I liked and I have the perfect person in mind who'll love it. Your version looks to have come out really well. I'll try and post a copy of my version, if / when I get a chance to make it.
Again. Thanks.
DavidWestley
Model of CNC Machine: X Carve
Re: Family plaque
Postby rarj4ever » Thu Sep 08, 2016 1:13 pm
thanks alot for the file.
rarj4ever
Model of CNC Machine: x-carve
Re: Family plaque
Postby cfreitas » Sat Sep 10, 2016 1:07 am
Thank you for the file. I really appreciate it. I have never used painters mask before and I have a couple of questions. Do you put it over the wood then let your bit cut the painters mask and the wood at the same time or do you use a vinyl cutter and cut the painters mask then place it over the wood and run the profile. I am sure I am overthinking this but would appreciate the help.
Thank you.
cfreitas
Model of CNC Machine: shopbot
Next
Return to VCarve - Gallery
