vase project
vase project
Postby martin54 » Sun Jun 12, 2016 5:13 pm
I don't normally post in the gallery but thought I had better put this one in as I had already asked some questions about cutting with or against the grain. This is taken from a vectric project by Michael. It is slightly larger than the original & the dome is a little flatter, that was actually an error, I thought I had to reduce the height of the dome because I was adding a component to it which I didn't have to do.
Front & back are Yew which I had never machined before but was very pleased with results, there are a few cracks/splits which I couldn't avoid. I picked up a few bits of yew at a good price because of this damage, with some projects I think they actually help to enhance the finished item (give it a bit of character) but don't think they really help in this case.
The 2 centre pieces are beech, I wanted a contrasting colour & had a bit of beech that happened to be the right sort of size & thickness, quite often I will use hornbeam or lime if I want a light coloured wood but I felt that this bit of beech was light enough. front & back are finished with Danish oil & the whole thing coated with clear varnish once glued together. I didn't want to coat the beech with Danish oil as it darkens the wood & I wanted to try & keep the contrast.
Just to give an idea how much Danish oil can darken a wood this picture is of a holder I made from the same piece of beech as the vase centres, the holder was given 3 coats of Danish oil as a finish.
Re: vase project
Postby bravesoul » Sun Jun 12, 2016 6:11 pm
Martin,
That looks really nice, would you mind sharing the file? If not I understand but I do like your's alot. If you can but want to leave out the 3d file, that's fine, I have plenty to add to it. Thanks for sharing, I have to get better at that myself and will starting doing so soon.
Joe
bravesoul
Model of CNC Machine: ShopBot PRT ALPHA 48"x96"
Re: vase project
Postby martin54 » Sun Jun 12, 2016 6:45 pm
Joe, its one of the vectric projects by Michael Tyler, you can find it here
http://www.vectric.com/cool-stuff/proje ... yVase.html
All I did was increased the size a little to fit the board width I had & added a 3d model instead of v carving & doing the inlay. The model is one of the ones that come with VCP8, all I did was place it & enlarge it to suit the front of the vase :lol: :lol:
Re: vase project
Postby scottp55 » Sun Jun 12, 2016 7:08 pm
Came out NICE Martin:)
scottp55
Re: vase project
Postby highpockets » Sun Jun 12, 2016 8:09 pm
Great job Martin!
I've looked at that vase just need a round to it...
Re: vase project
Postby Savannahdan » Sun Jun 12, 2016 8:11 pm
Been wanting to do one of those. Yours looks great, love it. Thank you for sharing.
Savannahdan
Re: vase project
Postby bravesoul » Sun Jun 12, 2016 8:40 pm
Martin,
Thanks for the info, I'll download it from Vectric and give it a shot soon.
Joe
bravesoul
Re: vase project
Postby martin54 » Sun Jun 12, 2016 11:39 pm
Thanks for the comments People, I do plan to have a go at the original inlay project but with a different vcarve design to the original. Having decided to use Yew for the back & front of this one I felt it would look better overall with a carved model rather than an inlay. With the colouring in the wood & an inlay I think there would have been to much going on :lol: :lol: :lol:
I have some Oak which is fairly plain so will use that for an inlay vase, just need to sort out a suitable design, probably keep the same Celtic theme on it though.
If this works out anything like the Paradise Box I will end up making quite a few of them at different sizes :lol: :lol: :lol:
Re: vase project
Postby mtylerfl » Mon Jun 13, 2016 12:12 am
Martin, that came out beautifully! I love the contrasting wood and the weaved model on the face of the vase. Very, very nice!
Re: vase project
Postby AndyPitts » Mon Jun 13, 2016 12:38 am
Well done, Martin, and thanks for the beech comparisons.
Andy Pitts
AndrewPittsFurnitureMaker.com
YouTube AndyPitts1000
AndyPitts
Model of CNC Machine: ShopBot desktop
Re: vase project
Postby glenninvb » Mon Jun 13, 2016 1:25 am
Martin,
Good job, like the Yew!
I may make a couple too.. thanks
glenninvb
Model of CNC Machine: homebuild / VCP 8.0
Re: vase project
Postby martin54 » Mon Jun 13, 2016 10:40 pm
I seem to have got stuck on a theme here, did this earlier today but not cut yet :lol: :lol: :lol:
Re: vase project
Postby highpockets » Tue Jun 14, 2016 5:36 am
Nice design to be stuck on.
What did you use to coat the inside, assuming it's meant to hold liquid.
Re: vase project
Postby martin54 » Tue Jun 14, 2016 10:07 am
I doubt if these are really meant to hold a liquid but I did coat the inside. What I did was to glue the 2 centre pieces together first, then I taped all the contact points on front, back & centre part to prevent them being covered. The inside of all parts were coated the same as the outside so danish oil for front & back & clear varnish for centre. Once the parts were dry I removed the tape & did the final glue up. I did use an exterior wood glue so in theory it should hold water :lol: :lol:
If I were to do one that was capable of holding water I would probably use the same process to ensure the whole of the inside was coated properly but use a more suitable coating.
Return to VCarve - Gallery
