I mentioned signfonts.com in a post on the Vcarve Pro general board.
"Long Lake" is one of the fonts I purchased from there. As Martin I believe said or alluded to, professional signmaker fonts will cause you a lot less grief than others.
"RANCH" is just in Zapf Humanist Ultra, which is one of the very few fonts you can compress vertically & have it still look good.
Long Lake Ranch
- T.R.MacMunn
- Model of CNC Machine: CAMaster MC4836
- mtylerfl
Re: Long Lake Ranch
Gorgeous work, TR!
Re: Long Lake Ranch
Yes +1 on that comment
- mezalick
Re: Long Lake Ranch
I like it
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- mtylerfl
Re: Long Lake Ranch
TR,
I just took another look of admiration at your sign! This time, I zoomed in on the photo and I noticed there is a nice background texture. Did you carve that, or is it some type of background material with a texture already on it? Whichever, it looks great and adds yet another touch of class that you are so well known for.
- T.R.MacMunn
Re: Long Lake Ranch
Michael, it's carved into the Corafoam.
It's a really easy texture ....... .125" tapered ballnose, set to 99% stepover. Cut your pocket at an angle ( this one is 30*) & cut the pocket again at the opposite angle ( in this case -30*.) I usually run it at about .30" depth. If you have small detail, you'll need an offset . I've never done it, but apparently it doesn't look so good with a .25" BN, but I don't know if it was a tapered bit, which would make quite a difference
- mtylerfl
Re: Long Lake Ranch
Thanks for the info! Nice, quick way to make a cool background texture!
Re: Long Lake Ranch
Well balanced layout, super execution. The texture and the "paint by number" look in the sky/clouds is cool.
Nice Work!
Neal
Nice Work!
Neal
- esteeme1
- Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Re: Long Lake Ranch
Outstanding Sign T.R. Well done. I always have appreciated your excellent craftsmanship.
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
"Can Do!"
