And, another design. This one has been slimmed so that two can be side by side to use on a double gang box. For toggle switches.
The back sides of all of these switch operators are pocketed so a regular switch plate can be glued in place. Most electrical codes require that switch plates be non-flammable.
Steampunk meets Frankenstein
- FixitMike
Re: Steampunk meets Frankenstein
- Tex_Lawrence
Mike, how did you hide the mounting screws? I don't see the heads.
- FixitMike
The mounting screws are under the sliding plate that moves the switch toggle. One is visible in this view.
