Butterfly Box
Re: Butterfly Box
Postby eagle-for » Fri Apr 14, 2017 8:15 pm
Love the Butterfly Box! I'm new to all of this so at the risk of showing my ignorance can someone hold my hand on how to attach the hinges to the lid? Are they glued or??
Help please :x
thanks
Cal
If this is in the wrong place please move.
eagle-for
Re: Butterfly Box
Postby Arnell » Sat Apr 15, 2017 12:05 pm
If you go to the second post and view the second picture you will see he used a wooden hinge.
Arnell
Model of CNC Machine: Zen
Re: Butterfly Box
Postby llwood » Sat Apr 15, 2017 6:33 pm
Cal, as Arnell wrote, there are other pages to this thread. If you look at the upper right on the page, you can see "Page 6 of 6" with little white squares around the numbers from 1 to 6. There you can go back to previous pages on the thread and read all the other discussion. Here's a direct link to page 4:
viewtopic.php?f=5&t=22383&start=45
On that page, you will find the following:
llwood wrote:... the hinge is a modification of a hinge design posted by Glenn in the Dresser Box thread: viewtopic.php?f=5&t=19336. He uses a steel pin and then replaces it with a bamboo skewer, but we use only the bamboo skewer right from the start. The skewer is inserted through all the hinge pieces. The hinge pieces are glued into the base first, then glued to one wing, then the other. If you haven't seen it, Vectric did a case study on this project, and it shows some more pictures of gluing on the wings and a description. You can see it here: http://www.vectric.com/cool-stuff/case- ... rtman.html
I think that will give you the information you are looking for.
Best,
Andy
llwood
Model of CNC Machine: Legacy Maverick
Re: Butterfly Box
Postby llwood » Sat Apr 15, 2017 6:36 pm
Here's another bit of information from page 4:
llwood wrote:...about glue, we didn't use wood glue because it takes too long to set. Instead, when Marty was doing the gluing, he used super glue. Hold it on for 20 seconds and it's secure.
llwood
Re: Butterfly Box
Postby JMD » Sat Apr 22, 2017 7:29 pm
Tried the "Butterfly Box". Think it came out good. :shock:
JMD
Model of CNC Machine: Shark Pro
Re: Butterfly Box
Postby rdean33422 » Sat Apr 22, 2017 10:29 pm
I had to try one also but started with a metal hinge and modified it.
Ray
rdean33422
Model of CNC Machine: RF31, 4X8 Router both CNC
Re: Butterfly Box
Postby llwood » Sun Apr 23, 2017 12:16 am
Wow, I love seeing all the variations!
Thanks for posting the pictures.
Andy
llwood
Re: Butterfly Box
Postby JMD » Sun Apr 23, 2017 2:12 am
rdean33422 wrote:I had to try one also but started with a metal hinge and modified it.
Ray
I like that idea :)
JMD
Re: Butterfly Box
Postby rdean33422 » Sun Apr 23, 2017 3:10 am
Thanks all
I work about evenly between wood and metal so I just combined them in this project.
Ray
rdean33422
Re: Butterfly Box
Postby flying_flip » Mon May 29, 2017 9:19 pm
I absolutely love these!
I plan on cutting the smaller version.
Raced out to Wood Workers Source, and bought the wood (8/4 and 1/2 Red Oak and 8/4 and 3/4 Padauk).
Got home and determined that I can't cut 8/4 on my Piranha :(
(hind sight is 20/20).
Currently looking to a friend to re-saw the 8/4 pieces, so that they fit on the machine.
I will post pictures when I get a chance to cut these.
flying_flip
Model of CNC Machine: Piranha FX / VCarve Desktop
Re: Butterfly Box
Postby Mike-S » Wed May 31, 2017 1:06 am
Doesn't it have 3" of Z travel? Or does bit length decrease that to something under 2"?
Mike-S
Re: Butterfly Box
Postby flying_flip » Wed May 31, 2017 11:53 pm
Yes 3 inches of travel.
8/4 board is almost 2 inches, and the cut required is ~1 3/4, so need 4inch travel at a minimum.
A friend has split the wood for me, so I will be cutting 7/8" and stacking the base pieces.
Phil
flying_flip
Re: Butterfly Box
Postby Creation in Wood » Thu Jun 01, 2017 3:46 am
Andy
Great job on the Butterfly Box. I like the wooden hung.
Thank You
Doug
Creation in Wood
Re: Butterfly Box
Postby woliver@atmc.net » Sun Jun 04, 2017 10:15 pm
Andy, got your files on the original butterfly box. Would you care to share the revision? thank you
woliver@atmc.net
Model of CNC Machine: sidewinder
Re: Butterfly Box
Postby llwood » Mon Jun 05, 2017 10:55 pm
woliver@atmc.net wrote:Andy, got your files on the original butterfly box. Would you care to share the revision? thank you
On page 2 of this thread, I shared two sizes of butterfly box, one smaller and one larger. I'm not sure what revision you are asking for.
Andy
llwood
PreviousNext
Return to VCarve - Gallery
Users browsing this forum: No registered users and 15 guests
