Hello.
A customer saw my bulls head sign and wanted a similar theme for a co owner.
Tooling 24mm 90Deg V at 10mm/s cut into 30mm NZ Rimu finished with Danish oil.
I now have a clean template I can use for similar works.
Yes his name is spelt correct, he has an odd way of spelling it.
Comments?
Regards
Bart
Vcarve sign
- Wemme
Vcarve sign
- (30.34 KiB) Downloaded 549 times
Re: Vcarve sign
-Wemme wrote:Hello.
Comments?
Regards
Bart
Nice work!
How did you go about getting the scroll work into VCW. Was it a image you imported into a drawing program?
This is all new to me but I'm slowly learning.
Chuck
- Wemme
Re: Vcarve sign
Hello Chuck.CRFultz wrote: Nice work!
Chuck
I mostly use alot of mdf But I really like the colour of hardwood.
Basically I borrowed the two swirly graphics from the "bullshead" sample from Vectric but had to redraw the rest in VCW
I Imported new text from Corel draw as an eps and then scaled moved etc in VCW.
FYI
I found some usefull free fonts here
http://www.xentrik.net/fonts/
I have bougth some clipart with no hassils from here after someone recomending them.
http://www.vectorart.com/store/
Check out Mega1 and Mega2
Regards
Bart
