Page 1 of 1
Countertop Turntables
Posted: Tue Dec 09, 2014 8:39 pm
by llwood
My sweetie's facing a health challenge so she's been taking lots of medications and vitamin supplements. The countertop was getting overwhelmed, so I designed these rotating multi-tier shelves to help store them more efficiently and still have them all accessible. Each has a riser in the top shelf so that smaller bottles are raised relative to the others. Lazy susan bearings allow them to rotate and the whole thing can be picked up and moved. This is also our first (well almost first) experience at using the wrapping gadget (for the posts).
Design by Andy, Cutting and Finishing by Marty (Thanks, Dad!)
- 3-tier in ash
- 2-tier in cherry
- Both the 2-tier and the 3-tier
Re: Countertop Turntables
Posted: Tue Dec 09, 2014 8:41 pm
by llwood
- Before
- After
Before and after pictures of countertop.
Posted: Tue Dec 09, 2014 8:54 pm
by rdean33422
Good job on the whole project especially the turning.
What did you put under the bottom level for feet?
Ray
Posted: Tue Dec 09, 2014 9:00 pm
by llwood
Thanks, Ray. Under the bottom level is a lazy susan bearing (12" for larger one and 9" for the smaller), with felt or rubber bumpers to keep the metal off the countertop.
--Andy
Posted: Thu Jan 22, 2015 11:56 am
by pops1964
Nice design , the daughter in law just seen this and wants a large scale one . pop's
Posted: Thu Jan 22, 2015 1:44 pm
by David Rueth
llwood
The shelves look great. The small lip on the shelves make it much nicer. I hope your sweetie gets well soon. That is a lot of meds on the shelves
Posted: Thu Jan 22, 2015 7:00 pm
by llwood
pops1964 wrote:Nice design , the daughter in law just seen this and wants a large scale one . pop's
Thanks, Pops. Would you like the .crv files?
--Andy
Posted: Thu Jan 22, 2015 7:03 pm
by llwood
David Rueth wrote:I hope your sweetie gets well soon. That is a lot of meds on the shelves
I really appreciate the sentiment, David. It's been more than 11 months since the diagnosis and things appear to be going well.
--Andy
Posted: Fri Jan 23, 2015 12:58 am
by pops1964
Ya if you don't mind it would be great . Thanks pop's
Posted: Fri Jan 23, 2015 7:23 pm
by llwood
pops1964 wrote:Ya if you don't mind it would be great . Thanks pop's
Here you go! I'm uploading 5 attachments, that we used for the 2-tier turntable.
1. The design document that shows what it's intended to look like when finished. It has dimensions and layers for the different bits that are used for the turning of the post.
2. The post, created with the wrapping gadget. On our machine the longer dimension is in the x direction, so it wraps Y to A.
3. Bottom shelf
4. Top shelf, same as the bottom shelf except that a hole is cut the whole way through that the post fits through.
5. Riser half. The entire riser on the top shelf is 2.5 inches thick, which is too thick to cut on our machine, so we have to cut 1/2 at a time. Each half has a roundover, and the rounded over edges are glued together to make one riser with a decorative groove in the middle. The riser is glued to the top of the top shelf.
Let me know if you have any questions.
--Andy
Posted: Fri Jan 23, 2015 7:24 pm
by llwood
Here's the rest of the attachments....
Posted: Sat Jan 24, 2015 11:45 am
by pops1964
Thanks for sharing . pop's
Posted: Fri Feb 06, 2015 1:05 pm
by sawmiller
thanks for the files, looks like it can definatly reduce countertop clutter, and it looks nice also.
