Countertop Turntables
Postby llwood » Tue Dec 09, 2014 8:39 pm
My sweetie's facing a health challenge so she's been taking lots of medications and vitamin supplements. The countertop was getting overwhelmed, so I designed these rotating multi-tier shelves to help store them more efficiently and still have them all accessible. Each has a riser in the top shelf so that smaller bottles are raised relative to the others. Lazy susan bearings allow them to rotate and the whole thing can be picked up and moved. This is also our first (well almost first) experience at using the wrapping gadget (for the posts).
Design by Andy, Cutting and Finishing by Marty (Thanks, Dad!)
3-tier in ash
2-tier in cherry
Both the 2-tier and the 3-tier
Closeup of post
llwood
Model of CNC Machine: Legacy Maverick
Re: Countertop Turntables
Postby llwood » Tue Dec 09, 2014 8:41 pm
Before
After
Before and after pictures of countertop.
llwood
Postby rdean33422 » Tue Dec 09, 2014 8:54 pm
Good job on the whole project especially the turning.
What did you put under the bottom level for feet?
Ray
rdean33422
Model of CNC Machine: RF31, 4X8 Router both CNC
Postby llwood » Tue Dec 09, 2014 9:00 pm
Thanks, Ray. Under the bottom level is a lazy susan bearing (12" for larger one and 9" for the smaller), with felt or rubber bumpers to keep the metal off the countertop.
--Andy
llwood
Postby pops1964 » Thu Jan 22, 2015 11:56 am
Nice design , the daughter in law just seen this and wants a large scale one . pop's
POPS1964
SHOPBOT Buddy BT-32
pops1964
Model of CNC Machine: shopbot buddy bt 32
Postby David Rueth » Thu Jan 22, 2015 1:44 pm
llwood
The shelves look great. The small lip on the shelves make it much nicer. I hope your sweetie gets well soon. That is a lot of meds on the shelves
David Rueth
Model of CNC Machine: Shark Pro Plus HD
Postby llwood » Thu Jan 22, 2015 7:00 pm
pops1964 wrote:Nice design , the daughter in law just seen this and wants a large scale one . pop's
Thanks, Pops. Would you like the .crv files?
--Andy
llwood
Postby llwood » Thu Jan 22, 2015 7:03 pm
David Rueth wrote:I hope your sweetie gets well soon. That is a lot of meds on the shelves
I really appreciate the sentiment, David. It's been more than 11 months since the diagnosis and things appear to be going well.
--Andy
llwood
Postby pops1964 » Fri Jan 23, 2015 12:58 am
Ya if you don't mind it would be great . Thanks pop's
POPS1964
SHOPBOT Buddy BT-32
pops1964
Postby llwood » Fri Jan 23, 2015 7:23 pm
pops1964 wrote:Ya if you don't mind it would be great . Thanks pop's
Here you go! I'm uploading 5 attachments, that we used for the 2-tier turntable.
1. The design document that shows what it's intended to look like when finished. It has dimensions and layers for the different bits that are used for the turning of the post.
2. The post, created with the wrapping gadget. On our machine the longer dimension is in the x direction, so it wraps Y to A.
3. Bottom shelf
4. Top shelf, same as the bottom shelf except that a hole is cut the whole way through that the post fits through.
5. Riser half. The entire riser on the top shelf is 2.5 inches thick, which is too thick to cut on our machine, so we have to cut 1/2 at a time. Each half has a roundover, and the rounded over edges are glued together to make one riser with a decorative groove in the middle. The riser is glued to the top of the top shelf.
Let me know if you have any questions.
--Andy
2tier Design.crv
(676.5 KiB) Downloaded 258 times
Top Shelf.crv
(921 KiB) Downloaded 242 times
llwood
Postby llwood » Fri Jan 23, 2015 7:24 pm
Here's the rest of the attachments....
Bottom Shelf.crv
(883.5 KiB) Downloaded 234 times
Riser half.crv
(212.5 KiB) Downloaded 215 times
Turntable Post.crv
(234 KiB) Downloaded 226 times
llwood
Postby pops1964 » Sat Jan 24, 2015 11:45 am
Thanks for sharing . pop's
POPS1964
SHOPBOT Buddy BT-32
pops1964
Postby sawmiller » Fri Feb 06, 2015 1:05 pm
thanks for the files, looks like it can definatly reduce countertop clutter, and it looks nice also.
In the heart of Tn
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Return to VCarve - Gallery
Users browsing this forum: hooby and 13 guests
