Happy Halloween! Spider on web
llwood
Post by llwood »
Top view
Top view
Thanks to all those who contributed to this design by participating in the discussion on this thread: http://forum.vectric.com/viewtopic.php?f=2&t=20870
--Andy
Design by Andy, Cutting and Finishing by Marty
Locust Lane Woodworking
llwood
Re: Happy Halloween! Spider on web
Post by llwood »
Here's another angle.
Side view
Side view
pops1964
Model of CNC Machine: shopbot buddy bt 32
Post by pops1964 »
Nice job.
POPS1964
SHOPBOT Buddy BT-32
llwood
Post by llwood »
And an indoor display also, on a plate holder
This made a great addition to our Halloween display that greeted the trick or treaters!
llwood
Post by llwood »
The picture wasn't showing up on my previous post, trying again....
llwood
Post by llwood »
Since Halloween is approaching (2 weeks), I thought I'd share my Spider on Web design in case anyone would like to use it for Halloween.
Enjoy,
--Andy
Spider on web.crv
(1.2 MiB) Downloaded 470 times
dwwright
Model of CNC Machine: JGRO
Post by dwwright »
Awesome job, I might try it out this weekend...Thanks for the share! :)
sharkcutup
Post by sharkcutup »
AWESOME!!! Thank You for Sharing!
Sharkcutup
V-Carve Pro 12.005
sharkcutup
You use 1/2 shank bits for your project. I am in the process of doing this project with 1/4" shank bits. I am now working the body segments in which you have used a 1/2" shank 3/4" pointed round over bit.
Are there any suggestions on other types of bits or tool paths that could closely resemble your spider body segments???
Sharkcutup
V-Carve Pro 12.005
bravesoul
Model of CNC Machine: ShopBot PRT ALPHA 48"x96"
Post by bravesoul »
sharkcutup wrote:You use 1/2 shank bits for your project. I am in the process of doing this project with 1/4" shank bits. I am now working the body segments in which you have used a 1/2" shank 3/4" pointed round over bit.
Sharkcutup
Check with Toolstoday.com, they have a 3/8" (3/4" roundover) pointed roundover with 1/4" shank. It's an amana so would be easy to find elsewhere too.
https://tools.toolstoday.com/search?p=R ... &view=grid
sharkcutup
Here is my rendering of the Spider in a Web with all 1/4" Shank Bits.
When my 1/4" shank pointed roundover bits (.25" radius & .375" radius) come in we will give this .crv file a run.
Sharkcutup
V-Carve Pro 12.005
llwood
Post by llwood »
We are thinking ahead this year, already ready for Halloween, with a painted version of the Spider on Web. Painting by Erica.
sharkcutup
Finally ordered and received the 1/4" shank pointed roundover router bits.
As promised here is my carving of the spider in a web using all 1/4" shank router bits.
Preparing early for halloween this year.
Lost a little meat from spiders left leg (intend to build it back up with little water-based wood filler) then sand & paint entire project. I had used a common pine board for the proto-type, I intend to create another using a better hardwood next time. I will just have to adjust feed/speeds accordingly (soft wood vs hardwood).
Sharkcutup
V-Carve Pro 12.005
dwilli9013
Post by dwilli9013 »
Nice I like it. Kind of puts the boot into me to start on my own halloween projects. Thanks for sharing.
D-Dub
Dwayne
Dwilli
Paul Stewart
Model of CNC Machine: Scratch Built
Post by Paul Stewart »
Love the spider nice work, good use of tools to create what looks to be 3d carving.
Here is a ghost i did a few years back and gave it to a little girl toward the end of trick of treating that night.
Done with 3/4" MDF and hand painted
