Trace BitMap Outcome
Postby knowlzy0791 » Fri Aug 01, 2014 5:48 pm
Ran across a thread yesterday about Tacing BitMaps. Had no idea how it worked so I got to messing around with it and kind of got the gist of it. Here is what I was able to come up with on my first go around with it.
Found the picture on a google search and just ran with it from there. Don't have any bits smaller than .25" so it could definitely be more precise but you gotta work with what you've got!
knowlzy0791
Model of CNC Machine: PAE 110SD Series/Mach3 Software
Re: Trace BitMap Outcome
Postby Samson » Sat Aug 02, 2014 1:47 am
That's pretty cool. Is it aluminum? Can you share info on the bit, feed speed and plunge rates?
Did you use any lubricant?
Samson
Model of CNC Machine: 4x4
Postby subsea » Sat Aug 02, 2014 3:00 pm
Nice trace. Did you do individual pockets or did V carve translate the different depths?
Best wishes, - Bill
subsea
Model of CNC Machine: Zenbot 2448
Postby knowlzy0791 » Mon Aug 04, 2014 2:40 pm
It is UHMW-PE. I used .25" end mill. Feedrate was set at 300IPM and i ended running about 55% of that. Plunge rate of 30IPM. No lubricant as it is poly.
Individual pockets and just played around with the depths to create "layers". Most complicated thing I have done so I'm sure there is plenty of room to improve.
Ordered a .125" bit and added lettering on 2 other designs so I'll be tryying those out later this week. Will update when they are done!
knowlzy0791
Postby knowlzy0791 » Tue Sep 09, 2014 8:18 pm
Was able to get my bit and finish putting the text in
knowlzy0791
Postby pops1964 » Wed Sep 10, 2014 12:25 am
Very cool nice job.
POPS1964
SHOPBOT Buddy BT-32
pops1964
Model of CNC Machine: shopbot buddy bt 32
Postby knowlzy0791 » Wed Sep 10, 2014 1:31 pm
pops1964 wrote:Very cool nice job.
Thank you very much
knowlzy0791
Return to VCarve - Gallery
Users browsing this forum: No registered users and 9 guests
