Cthultha nightlight
Cthultha nightlight
Postby FixitMike » Fri Jan 31, 2014 5:38 am
Material: 3/8" cast acrylic, walnut.
VCarve toolpath
90 degree V bit
.030" deep
Final pass stepover: .005
Feed rate: 100 ipm
Plunge rate: 30 ipm
Flat area clearance: Offset
Climb cut
LED strip, power supply, and connector from SuperBrightLEDs.com
FixitMike
Re: Cthultha nightlight
Postby Phil » Fri Jan 31, 2014 2:50 pm
Very nice. Thanks for the info.
Phil
Phil
Postby Phil » Fri Jan 31, 2014 3:10 pm
I went to SuperBrightLEDs.com. Wow, there are a lot of items to choosed from. I'm interested in doing an LED/Acrylic project but I need to know what to but. Can you tell me which power supply and connector you used?
Phil
Phil
Postby FixitMike » Fri Jan 31, 2014 4:15 pm
Here's what I bought:
Qty Product/Options Price/Ea
1 NFLS-NW30X3-WHT Natural White 15.95
2 NFLS10-2CHCPS Adapter CPS Cable Clamp 3.49
2 CPS-12VDC-6W 6 Watt - 12VDC 10.95
Note that the power supply is less expensive at Amazon.com. I suspect equivalents for the others might be too.
Another note: The viewing is best from the back side. So if there is any text, it will be best if you mirror it before carving.
FixitMike
Postby Paul Kierstead » Fri Jan 31, 2014 5:14 pm
That is an exceptional Cthulhu design, with the right level of menace and fun. Now I really want to make one of these for my 14-month old daughter, who we used to put to sleep with "cthulhu sleeps"!
Paul Kierstead
Model of CNC Machine: Probotix V90
Postby Phil » Fri Jan 31, 2014 10:35 pm
Thanks for the info FixitMike.
Phil
Phil
Return to VCarve - Gallery
