2D milling
2D milling
VCarve is excellent for 2D milling also
Here you can see two happy customers, with my latest work.
Haavard
Haavard
- Trex
- (79.49 KiB) Downloaded 814 times
Haavard Solvang
2D milling
Cool!
- Paco
Re: 2D milling
...VERY!Phil wrote:Cool!
If you ever felt like sharing the CAD and material info...
Keep us posted of your good work!
- RoutnAbout
You can find the drawing here:
http://www.cnczone.com/forums/showthrea ... light=dino
Material: 9mm plywood
Haavard Solvang
Attached is the VCW file for the Dino from CNCZone that Riven machined for his children.
This file is setup for 3/8" thick material and requires a 39" x 27" sheet size.
The toolpaths are for a 1/4" dia End Mill and will cut each shape in 2 passes - modify as required.
Let me know if you would like to cut the Dino from thicker / thinner / metric material
and I'll send you the scaling instructions.
I'll post a Video Tutorial in a day or two.
Tony
Tony
- (37.19 KiB) Downloaded 529 times
- (157.25 KiB) Downloaded 562 times
- (120.36 KiB) Downloaded 561 times
- Dino_ 0.375_inch_matl.zip
- (817.29 KiB) Downloaded 532 times
- Wemme
Well I hacked out a Dinosaur. Due to some parts getting munched up by the spindle cutter when they came free i had to cut about 8 replacement parts.
One more reason for tabbing hint hint other wise Great fun and even the misses thinks its Awesome.
- (43.67 KiB) Downloaded 494 times
- (42.93 KiB) Downloaded 472 times
- (89.22 KiB) Downloaded 527 times
- RoutnAbout
The video and pictures below show the Dino being routed from 3/8" (9mm) plywood on a Pacer router.
This router has Vacuum Table that makes holding the material very easy. The cutter was a 1/8th (3mm) single flute, downcut and it took approximately 30 minutes to cut out all the pieces.
Tony
Video clip
(may take a few minutes to start)
Tony
Video clip
- Model of CNC Machine: shopbot 48 x 96 laser engraver
A few years back when i got my router a guy i was talking to about the router gave me a font called Dinos font
you put in your font folder call up a font (i call it up in mastercam scale it to the size i want than cut it i did one 48 x 96 sheet.)you can do it any other software that you can use fonts here is list of fonts you can cut just call up Dinos font type in( a is apatosaurus)a list is below
a apatosaurus
B brachiosaurus
M mammoth
P pteranodon
p parasaurolophus
S stegosaurus
s spinosaurus
T t rex
t triceratops
U styracosaurus
z plesiosaurus
there is a assemble zip file a Dinos font zip file i just got PhotoVCarve last week
and joined this site looks like a real good program if someone want it i can email them to you
Jim Walters
a apatosaurus
B brachiosaurus
M mammoth
P pteranodon
p parasaurolophus
S stegosaurus
s spinosaurus
T t rex
t triceratops
U styracosaurus
z plesiosaurus
Jim Walters
- (45.83 KiB) Downloaded 556 times
Model size
Is there an easy way to determine the size or height of the model? This will be a great gift for my grandson at Christmas. Many thanks.
Norm Weller
Evans, GA
Norm Weller
Evans, GA
I just analyze in mastercam the longest parts check the assemble drawing check where legs go in. head size(if standing up right) or top of back than i scale to a a size i think it will be hope this helps
Jim W
Jim W
