This one is 20" diam. cut out of 1/2" Baltic birch Ply. About 4hr. cut with 1/2 90 deg. v-bit.
John (Beyond Carving) .... and the world is still here
Another Aztec Calendar
- Model of CNC Machine: AXYZ 5010
Re: Another Aztec Calendar
That is quite nice John. Was there any problem with chipping out with the birch ply?
Paul Rowntree
These are even more valuable now. Simply because we can still make them.
CarveOne
CarveOne
CarveOne
- zeeway
Not to claim jump here, but you can first finish with metallic copper paint - let dry for 24 hr - then rub in cherry gel stain. Shellac or poly when dry.John Murphy wrote:I like the finish. How did you do that?
Angie
First, I had no trouble with the Baltic birch chipping out. Sharp 90deg.1/2" v-bit -- no problem.
Baltic ... not local.
As for the finish, one coat bullseye sealer shellac, one coat clear minwax stain, followed within
a half hour with 230 Early American Minwax stain (wipe off surface for light accents), ( time for drying ), then more bullseye,
then a light high-light rub with Classic gold paint, then a couple more spray-on coats of Bullseye
or clear satin Krylon. Enjoy.
John .. (Beyond Carving)
