PVC Louver Panel
PVC Louver Panel
Postby sharbold » Fri Jul 20, 2012 2:13 am
This is a PVC Panel with a closed louver look.
Panel with Louver Revised_6.pdf
(2.67 MiB) Downloaded 255 times
sharbold
Model of CNC Machine: 12 year old ShopBot
Re: PVC Louver Panel
Postby IBBruin » Fri Jul 20, 2012 2:41 am
I'm a craft beer brewer. I can brew beer that taste like Bud, Coors, Miller but why would I? Those can be easily be purchased. Once you unlock the full potential of your software, you will be one of the upper tier of CNC'rs.
IBBruin
Model of CNC Machine: Homegrown
Postby tmerrill » Fri Jul 20, 2012 10:15 am
Hi Sam,
The doors look great! In your other post you mentioned the door halves were laminated together. If you don't mind, what did you use for an adhesive?
Thanks for posting.
Tim
tmerrill
Model of CNC Machine: ShopBot
Postby sharbold » Fri Jul 20, 2012 1:10 pm
IBBruin, thanks for the compliment.
Tim, I used Bond & Fill Thinset Lamination Adhesive
http://www.bondfill.com/bond-and-fill-thinset-lamination-grade
Sam
sharbold
Postby tmerrill » Fri Jul 20, 2012 2:02 pm
Hi Sam,
Thanks for the info and link. I've bookmarked it for future use.
Tim
tmerrill
Postby Paul Z » Fri Jul 20, 2012 3:38 pm
Sam,
Thanks for the info one the adhesive.
Paul Z
Paul Z
Model of CNC Machine: shopbot PRT Alpha 96x48
Postby Mike-S » Fri Jul 20, 2012 5:12 pm
Nice louvered panels. :D
And thanks for the adhesive link. They also carry the hard to find plastic biscuits.
Mike-S
Postby rscrawford » Sat Jul 21, 2012 4:27 am
Looks good. What was the cut time on that panel? Wondering if it would be faster to make a real louvred panel the old fashioned way (maybe using the CNC for the louvre mortises, or pin holes if the louvres opened and closed).
Russell Crawford
rscrawford
Model of CNC Machine: CAMaster Cobra 408 ATC with recoil
Postby sharbold » Sat Jul 21, 2012 12:34 pm
Each louver panel took 14 minutes to machine so a total time of 56 minutes to machine the 4 panels. Also the customer wanted the louver look but did not want any openings for insects to get behind.
sharbold
Postby rscrawford » Sat Jul 21, 2012 12:43 pm
I'm very impressed you can machine those panels in 14 minutes. You've shown some well designed, clean work.
rscrawford
Postby fretsman68 » Sat Jul 21, 2012 12:56 pm
Absolutely beautiful, sharbold, may I ask where you get your PVC material and is there a "brand" you prefer?
Dave
Dave
fretsman68
Postby sharbold » Sat Jul 21, 2012 10:47 pm
rscrawford wrote:I'm very impressed you can machine those panels in 14 minutes. You've shown some well designed, clean work.
To better clarify here is a quick breakdown of how I machined the Louver. Each louver panel was cut into a 1/2" piece of PVC. Then the panel was inserted into a rabbit cut in the back of the 1" PVC which has the stile and rail cut. The louver panel was cut the exact size as the opening in the 1" PVC then a 1/2" thick PVC spacer was applied around the louver to lock it in. This way there are no voids for dirt or bugs to get into.
Louver panel with spacer
Here are a couple shots of the vacuum jig I used to hold the 1/2" PVC to machine the louvers. To not get into a problem with clearance issue with the Z axis I decided to machine the louvers as 2 panels then glue them together. Machining time for each half of the louver was 6 minutes 15 seconds. So total time to produce 2 halves including change out was 14 minutes.
Vacuum jig to hold 1/2" PVC. View_1
Vacuum jig to hold 1/2" PVC. View_2
Vacuum jig to hold 1/2" PVC. View_3
I used an Amana RC2250 cutter which done an excellant job on the louver.
Amana RC 2250
Sam
sharbold
Postby sharbold » Sat Jul 21, 2012 10:50 pm
fretsman68 wrote:Absolutely beautiful, sharbold, may I ask where you get your PVC material and is there a "brand" you prefer?
Dave
Dave I use both Azek and Versatex but of the two I prefer Versatex. The versatex seems to have a more dense core and the thickness is more precise. Azek I purchase from Parksite Plunkett Webster and the Versatex I purchase from TW Perry. Both companies are located in Baltimore.
Sam
sharbold
Postby fretsman68 » Sat Jul 21, 2012 11:32 pm
Dave
Sam
Excellent, thank you, Sam-
Dave
Dave
fretsman68
Postby rscrawford » Sat Jul 21, 2012 11:51 pm
When you said 14 minutes, I suspected you must be cutting those on a tapered jig! Most posters on here would simply use a finish toolpath and waste 6 or 7 hours of machine time, without getting those nice clean lines.
What kind of a vacuum are you using? I have an older dental vacuum unit (wet ring) that will pull 60cfm at 22"Hg. I use a 1/2" hose with quick connectors to hook up to my different jigs, and I use 1.5mm natural rubber sandblasting mask as the gasket. I cover the whole surface of my jig with the rubber, then cut out sections of the rubber to act as the plenum (since I'm going for an airtight seal, I don't need a deep plenum because there is virtually no airflow). This gives an airtight seal and I can cut out pieces less then 5cmx5cm with no movement.
Russell Crawford
rscrawford
Next
Return to VCarve - Gallery
