bass master plaque
tonydude919
Model of CNC Machine: cnc mako shark ext bed with HD 5 gantry
bass master plaque
Post by tonydude919 »
Here is a plaque I did for someone in wny bass masters.
John Murphy
Model of CNC Machine: AXYZ 5010
Re: bass master plaque
Post by John Murphy »
Well Done Tony!
It looks like two different pieces of wood. Can you tell us how you finished this?
tonydude919
I did the bass out of oak in cut3d and then impoted the model in vcarve. Figured out my lettering, did the toolpaths and glued the bass on the pine plaque after the lettering was carved out.
rej
Model of CNC Machine: 2014 roc-tech 4x8 with servos
Post by rej »
nice job tony.
http://www.3dsigncamp.com
http://www.roctechusacnc.com
esteeme1
Post by esteeme1 »
Very well done, I like how the grain pattern came out.
Jim Darlas
"Can Do!"
zeeway
Post by zeeway »
Very clean design and execution. I especially like the oak grain in the bass.
Angie
mikeacg
Post by mikeacg »
It looks great Tony! Thanks for sharing!!
I would check your table for level though as it appears that you have deeper cuts on the left side of the pine plaque.
Mike
tonydude919
Mike, the reason is I sanded the edge too much, thats why it came out that way.
Tony
mikeacg
Post by mikeacg »
I wasn't busting your chops - just wanted to be sure, Tony!
One of my earliest signs I carved in PVC for a sign shop. It was roughly 4' x 6' and took about 6 hours to run (Lots of small type). Looked great when it came off the machine, white on white, but when they put the paint into the letters... YIKES! A learning experience for me!
Mike
