Routed Jewelry Box
Re: Routed Jewelry Box
Postby Bob Jr » Tue Feb 18, 2014 7:02 pm
Since we're on the topic of hinges, Michael Tyler posted plans for a hinged picture frame in Aug, 2011. http://www.vectric.com/cool-stuff/proje ... -frame.htm
I modified his idea and started making wooden hinges. This basic idea went in many different directions, but here's what I did with the hinge venture:
Here is the file I developed for hinge making.
You could use tabs to hold parts to the board. I used carpet tape to attach the wood to a spoil board. The holes drilled in the wings of the hinges are for the insertion of alignment dowels. This makes it easier to glue the assemblies. All cuts were made with a .125 end mill.
Bob
hinges.zip
(575.1 KiB) Downloaded 377 times
hammer...nails...stuff
Bob Jr
Model of CNC Machine: CNC Shark, Axiom,Phoenix
Postby Ms Wolffie » Tue Feb 18, 2014 11:36 pm
Thank you Bob
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Postby SPalm » Tue Feb 18, 2014 11:44 pm
Hey Bob, That is pretty cool.
I will have to try that. I need to get a small bit though. Seems like it works ok.
SPalm
Postby glenninvb » Wed Feb 19, 2014 11:02 pm
Here is .CRV for small hinges (for 1/2" thick top, surface glued.
Material .5 The pocket was for 3/8" thick pulls
1/8" downcut endmill for hinges and hinge pin holes (bamboo skewer fits nice)
jb box hardware.crv
(809 KiB) Downloaded 416 times
glenninvb
Model of CNC Machine: homebuild / VCP 8.0
Postby SPalm » Thu Feb 20, 2014 12:06 am
Sweet. That looks great.
Love those bamboo skewers.
SPalm
Postby glenninvb » Fri Feb 21, 2014 8:20 pm
SPalm's jewelry box
Last photo of jewelry box, I promise
And only 1000 hours later! (good thing I don't do this for a living :) )
And I did put tiny button magnets in back of drawers that hit set screws, just the right pull
Glenn
glenninvb
Postby SPalm » Fri Feb 21, 2014 8:31 pm
You go Glenn. Looks mighty fine.
I didn't know that you were going to make a piano hinge. Really good idea.
I am glad that I don't try to make a living at this either :)
SPalm
Postby glenninvb » Fri Feb 21, 2014 10:00 pm
Hello Steve,
I was thinking your design (shape) would make a nice box (men or woman's) if I only make the top tray and top.
A little thicker, maybe 1 1/4 -1 1/2 top tray with a wood piano hinge, would be quick to make and then engrave or inlay initials in top.
The wood hinges where surprisingly quick to make and attach with medium gel CA glue, they cut really clean in dense wood like the Yellowheart I used
Good gifts or item to sell.
You could get fancy and laminate different woods, would look good too.
Thanks, Glenn
glenninvb
Postby BArnold » Sun Sep 13, 2015 8:19 pm
I downloaded the Jbox file and have been looking at it. One thing I ran into can best be demonstrated by the attached screenshot. There's a lot of unnecessary cutting at the top of the piece. I can see no reason for this to happen - no apparent extraneous stuff in the drawing. Any ideas?
BArnold
Model of CNC Machine: SO2/XCarve hybrid w/NEMA23 on all axes
Postby SPalm » Sun Sep 13, 2015 9:05 pm
Hey, I'm camping right now and only have an iPad so I can not check it. But it looks like you have too many layers turned on. The bottom should only have the outside profile and five drill holes (I think, it has been a long time).
Look at the last picture on the first post of this thread. It shows all the pieces individually, along with the back piece that will fit into three of these drill holes.
I hope you can figure it out, or someone else with a computer can help.
SPalm
Postby BArnold » Sun Sep 13, 2015 9:46 pm
There are two layers in the file I downloaded: Top Tray and Small Tray. In the photo I posted, only the Small Tray layer is on.
BArnold
Postby BArnold » Sun Sep 13, 2015 10:00 pm
Below in the photos I have one layer at a time turned on. In both cases, the cut runs off path. Actually, it looks like the cut starts off path, then ends off path. In any case, it's unnecessary cutting.
BArnold
Postby daveh » Mon Sep 14, 2015 5:06 am
Looks like a toolpath lead in and out to me. Helps to prevent marks at the start and end of the cut.
daveh
Model of CNC Machine: Joes CNC
Postby BArnold » Mon Sep 14, 2015 3:43 pm
daveh wrote:Looks like a toolpath lead in and out to me. Helps to prevent marks at the start and end of the cut.
Thanks, Dave. That's what it is. I see now that I can turn leads on and off; might come in handy for some of my stuff.
I've had VCarve for a few weeks and still have a lot to learn. :shock:
Thanks again!!!
BArnold
Postby glenninvb » Mon Sep 14, 2015 7:19 pm
Thanks again!!!
SPalm, sent me a PM and asked me to look as I built one of his boxes, but seems you have figured...... leads.... use if you wish or eliminate. I think I used and it does eliminate tool marks. SPalm designs nice projects and his other goodies are very nice as well.
P.S. Steve...... have a great time camping :)
glenninvb
PreviousNext
Return to VCarve - Gallery
