Routed Jewelry Box
Re: Routed Jewelry Box
Postby chrisb691 » Wed May 23, 2012 11:36 pm
Thank you so much Steve. I had a go at it, with a slight mod. I have replaced the base with another tray. Timber is Tasmanian Oak, with Merbau funiture.
The only problem, is that you have got me onto a slippery slope. 2 daughters now want one, which I expected. 2 sisters want one, wasn't expected. 9 nieces have put up their hands...oh crap!
chrisb691
Postby SPalm » Thu May 24, 2012 12:38 am
SWEET!
Good job. You brought a smile to my face. And what a wonderful inlay you put on the top.
Making more huh? Take it as a compliment, you deserve it.
We did have a family debate on whether to make the bottom a tray. I lost - you won. I like it, although it is a little hidden.
I think it is kind of neat making something other than signs with VC. Stretches the thinking cap.
Once again, it looks great.
SPalm
Postby chrisb691 » Tue May 29, 2012 6:05 am
Thanks for that Steve, but the credit goes to you.
I just realised that I posted one of your photo's, my apologies for that...it was definitely unintentional. :oops: Should have been this one.
chrisb691
Postby shearder » Tue Jul 09, 2013 1:58 pm
May I ask how you did the outside of the salt boxes? It isn't simply cut out.
Thanks :?
shearder
Model of CNC Machine: XJ1212
Postby SPalm » Tue Jul 09, 2013 7:12 pm
@shearder:
If you mean the scallop on the sides of the Salt Box that I did, (not this box) I used the Flute feature.
Go to this link:
viewtopic.php?f=5&t=12440
And see the design files that use it in post # 9 ( you can load and watch it yourself)
And I did a quick explain in post # 12
I hope this helps,
SPalm
Postby Daniel S » Mon Jul 15, 2013 8:43 am
Thanks for the file.... My Granddaughters will love them.
Dan :)
Daniel S
Postby IceStorm » Wed Jul 17, 2013 1:02 am
Great job Spalm,
Real nice design, Thanks for the down load !!
Have to try one.
BeSafe, IceStorm
IceStorm
Model of CNC Machine: Shark Pro
Postby menida » Tue Feb 04, 2014 6:15 pm
Thanks very nice
menida
Model of CNC Machine: CNC Shark
Postby Greg Green » Sat Feb 15, 2014 7:31 am
Many Thanks :)
Greg Green
Postby Greg Green » Sat Feb 15, 2014 7:32 am
Many Thanks :)
Greg Green
Postby glenninvb » Sat Feb 15, 2014 3:25 pm
SPalm,
Thanks again for the .CRV, just started one last night, I barely have enough Mayan Walnut to complete (and can't find more), better not screw up!!
Greg, great job, also here is a inlay design I cleaned up that would be nice for a young girl's jewelry box, if your interested feel free
childs play.crv
(110.5 KiB) Downloaded 418 times
glenninvb
Model of CNC Machine: homebuild / VCP 8.0
Postby SPalm » Sat Feb 15, 2014 9:19 pm
Hey Glenn,
Mayan Walnut, sweet. That looks like some really nice carving. Hope it works out for you.
And your design file downloaded, thanks.
SPalm
Postby glenninvb » Mon Feb 17, 2014 11:47 pm
SPalm,
Steve,
If your around, can you tell me if you made the wood hinges or you bought them?
I made one small change, not drilling the three center dowel holes, I'm going to glue the top tray to the back block and then attach with a couple #6 screws from bottom. The two dowels seem to keep everything lined up.
One tip, (you may have done this) I clamped the whole works together (w/o spacers of course, but with dowels installed) and sanded the "block" with the DA and then hand block to 320
90% of the hard sanding quick
Thanks again for the file :D
P.S. I may mill a groove in the back panel for a magnetic strip, my wife never closes drawers all the way :o
glenninvb
Postby SPalm » Tue Feb 18, 2014 2:03 am
I did the same sanding trick, but yours looks a lot better. Looks like a good idea with the assembly, it'll be nice to see the results.
I used some homemade wooden hinges. Mostly because I am cheap. Here is a link to how I made them:
http://lumberjocks.com/projects/36519
SPalm
Postby glenninvb » Tue Feb 18, 2014 4:47 am
SPalm,
I've known about wood hinges for years but never had a reason to use them. If I'm going to make wood pulls, may as well go with wood hinges for your fancy little box. I'll try my box joint jig to index the slots.
I web searched wood hinges and I guess nobody sells any. You would think by now someone would be mass producing them. (machine made)
Oh, I don't believe the part about being cheap, anyone that owns a cnc router, can't be but so cheap! :mrgreen:
Glenn
glenninvb
PreviousNext
Return to VCarve - Gallery
