Routed Jewelry Box
Routed Jewelry Box
Postby SPalm » Mon Dec 12, 2011 2:00 am
The cherry drawers and tray are 1 inch thick, the top and bottom are 1/2 inch. The basic carcass is held together with five 1/4 inch dowels. Two are used as hinge pins for the drawers, and the other three are hidden inside the back. I made the back plate out of separate pieces to keep the assembly easier – dowels are so unforgiving. The drawers press against this back plate which allowed me to slightly sand the back of the drawers until they closed with just the front gap that I wanted. I used brass washers to separate the drawers. It all worked out quite nicely in the end.
I am posting the design file. Feel free to use or modify it if you want. I stripped out any special tabs and clean-up routing to keep it simple. You may want to modify the back plate concept to match your woodworking skills. I used a wooden hinge, but a lift off top would be nice also. The drawers work better with a finger grab and I used glue on walnut knobs for this, but there are lots of options.
Jbox.crv
(435.5 KiB) Downloaded 3109 times
SPalm
Re: Routed Jewelry Box
Postby jasond » Mon Dec 12, 2011 2:23 am
Very nice! Thanks for sharing
jasond
Model of CNC Machine: Homemade cnc
Postby jam1962 » Mon Dec 12, 2011 3:42 am
Looks like the begining stages of a "Project of the Month".. :?: . I like it.
Thank you for sharing the file and idea, this is now on the list of things to get around to.
Jay Morris...
jam1962
Model of CNC Machine: Self built 36x25x7
Postby calgrdnr » Mon Dec 12, 2011 4:44 am
Looking very Good and thanks for sharing Kent
calgrdnr
Model of CNC Machine: ShopBot prt with 4g upgrade
Postby Bob Reda » Mon Dec 12, 2011 11:05 am
Thanks for the generosity!
Bob
Bob Reda
Postby zeeway » Mon Dec 12, 2011 12:14 pm
Steve,
Thank you again for another innovative design. I will add this to my "Spalm box" collection.
Angie
zeeway
Postby SPalm » Mon Dec 12, 2011 1:11 pm
Hey People,
The CRV file above is from Version 6.5, so I guess if you don't have that version you can not load it. Here are the DXF exports from my two main working layers.
The 'Large' layer contains the profile, pocket, and drill for the top, the top tray, and the bottom. The top is routed with just the profile. The top tray is routed with the profile and the pocket. The bottom is routed with the profile and the 5 drills. I drilled all the way through the bottom for ease of dowel insertion and then also used this as a manual drill template for drilling the bottom of the top tray with a drill press.
The small trays are routed, pocketed and drilled. They are routed two at a time for grain matching.
Just a thought. If you want a lift off lid, you could route a reverse pocket on the top's underside. This would create a indexing protrusion on the bottom of the top to keep it in place. Also the flat top is a perfect canvas for some VCarving.
JboxLarge.dxf
(37.54 KiB) Downloaded 1679 times
JboxSmall.dxf
(34 KiB) Downloaded 1439 times
SPalm
Postby davewierenga » Mon Dec 12, 2011 6:46 pm
Nice jewelry box, thanks for sharing.
Dave :D
davewierenga
Model of CNC Machine: Stinger1
Postby LoneTreeCreations » Tue Dec 13, 2011 2:29 am
Thank you Steve, I'm excited about trying this one for my wife.
Pete
Lone Tree Creations
LoneTreeCreations
Model of CNC Machine: Blackfoot v4.1 4x4 home built router
Postby galerdude » Tue Dec 13, 2011 12:47 pm
Nice share!
Gale
Regards,
Gale
galerdude
Model of CNC Machine: Joe's 4x4 Hybrid R&P Evolution
Postby kzeyus » Tue Dec 13, 2011 1:35 pm
Very Nice!
Thank you!
Ken Zey
Rogers, AR
http://www.CedarSlabSigns.com
http://www.lookoutmercantile.com
Shopbot PRS Alpha 72x144
kzeyus
Postby ssflyer » Wed Dec 14, 2011 4:21 am
I love the drawers! Tanks for sharing, Steve!
Ron Sloan
ssflyer
Model of CNC Machine: ShopBot PRSAlpha 96x60
Postby jsantos » Wed Dec 14, 2011 11:53 pm
Really nice! Thanks for sharing.
jsantos
Postby PeteC » Tue Dec 20, 2011 9:22 pm
Thank You for sharing. I think I'll try it. :D Let you know how it comes out. :wink:
Bigfoot
PeteC
Model of CNC Machine: Probotix FireBall Comet
Postby glenn » Wed Dec 21, 2011 12:22 am
Thanks!
glenn
Model of CNC Machine: home brew 40x20
Next
Return to VCarve - Gallery
Users browsing this forum: Google [Bot] and 11 guests
