christmas wreath
christmas wreath
I am looking for a free Christmas wreath for V carve Pro
Re: christmas wreath
Use your favorite search engine to look for
Christmas wreath coloring page svg
Even though you're looking for something "free", the Christmas Wreath on the Design & Make site is really nice. That's if you're looking for a 3d file. Otherwise, do as Randall suggests and do a search.
- Model of CNC Machine: salecnc XJ1224
There is a Christmas wreath in the Vectric newsletter issue 24 November 2011, its for aspire version 3.5 so I'm not sure if the current v carve pro version can do it?.
regards
Brian
regards
Brian
- dhellew2
It should work fine... once saved in a later version you cannot go back to a prior version.
I opened it with v9.5
Dale
Dale
Young = time, no money
Old = money, no time
Dale
Dale
VCarve cannot open Aspire files.its for aspire version 3.5 so I'm not sure if the current v carve pro
- sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
This is the one I did from the Nov 2011 free projects and hung it on my front door for Christmas. I guess I have to make another one. Somebody liked it better than I did and stole it. Great way to honor Christmas.
https://www.vectric.com/cool-stuff/proj ... reath.html
- mtylerfl
I don’t blame them for stealing it - you did a fantastic job! Not sure it would be worth time in the pokey if caught with the goods, though!
As has been pointed out the vectric one from 2011 is Aspire only, the OP is running Vcarve
This year you need to make a lockable polycarb display case to bolt on the door as well
Won't deter everyone but should eliminate the opportunists
- sharkcutup
Here is another wreath using 3D Clipart Bells supplied with VCarve
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- Model of CNC Machine: CAMaster Stinger SR-23
Just to add my two cents. In 2014 I purchased a pattern from Judy Gale Roberts to be cut out with scroll saw, I'm not the best at that skill, so I converted the drawings to vectors and cut the parts out with my Shark ( old Shark Pro). Then with sanding and fitting I ended up with a wreath that my wife still enjoys today. I believe the price for the pattern was under 10 dollars.
Dan
Dan
- Model of CNC Machine: Shark Pro HD
Dale. How did you open it with v9.5? Were you using V-Carve or Aspire?dhellew2 wrote:It should work fine... once saved in a later version you cannot go back to a prior version.
Dale
Stephen
