Second try at doing an edgelit. Just made the base and fit to see if it works. Its for my Grandson who I've made 5 other clocks for. He really is the Worlds Timekeeper.
Dave
edgelit clock
- Model of CNC Machine: Probotix Meteor 25 x 50
edgelit clock
Dave
- Model of CNC Machine: CNC 6040, Vectric Aspire, UCCNC
Re: edgelit clock
Nice work.
What tool did you use?
Re: edgelit clock
I used a Widget 120 degree diamond drag bit. Seemed to work good.
Dave
Dave
- Xxray
Re: edgelit clock
Nice job, lettering is crisp and the base looks nice.
Keep in mind you can use mirrored plexi if you'd rather not have the movement visible.
Painted white plexi also a nice variation, here you can see where the box is by its shadow, no way to avoid that since its backlit by necessity.
- dwilli9013
Re: edgelit clock
Yeah Doug. I thought if I etched it a little bigger than the movement it would hide it. Live and learn. Thanks for a good suggestion.
Dave
Dave
