Box gadget Question
Box gadget Question
Postby newcarver » Tue Jan 14, 2020 3:45 am
I am new to Aspire and have been playing around with the box making gadget V9. I have a few newbie questions if anyone can help.
I sometimes get a box that just won't fit together meaning 1/8 too big or 1/16th too small. I usually run an 1/8 end mill with the tool path cutting on the line. I set the gap to .005. Do you have to run the tool path to cut on the line or outside of the line?
The gaps i am getting is about half the diameter of my 1/8" end mill.
My other question is if i want to make alot of boxes on a 4x4 plywood sheet can you copy and paste the first box or should you use array function?
I noticed when you try to move the box the original outline of the box always stays in the LH corner of my project. I like to move it over some so i can place a clamp there.
newcarver
Model of CNC Machine: Axiom
Return to Gadgets - General
Users browsing this forum: No registered users and 9 guests
