A couple gadgets not working
Postby Allen » Mon Dec 23, 2019 12:36 am
Hello,
I have a couple gadgets I down loaded and installed, when started they say they need a "nil value".
How do I fix this?
Thanks in advance
Allen
Model of CNC Machine: Built it myself/ Linuxcnc control
Re: A couple gadgets not working
Postby jimandi5000 » Mon Dec 23, 2019 12:55 am
Hello Allen,
Hope you're having a fantastic day.
First, it would helpful if you could provide the name of the gadget you are working with.
Second, do you have a working experience with any type of software development?
Please let me know on these and I will do our best to help or guide you.
Jim
jimandi5000
Postby Allen » Mon Dec 23, 2019 6:14 pm
Hi Jim,
Yes, I'm enjoying the Holiday vib, everyday is a blessing.
Hope you're able to embrace the season as well.
Gadgets with this issue:
Box creator
Chamfer
Valance
I'm no coder to be sure, little things are doable.
These are just something to play with, so if they're too difficult to get working it's no big deal.
Thank again
Allen
Postby jimandi5000 » Mon Dec 23, 2019 6:48 pm
Allen wrote:Hi Jim,
Box creator
Chamfer
Valance
Thank again
Hello Allen,
My first guess, it would be the tool library has change structures in version 10. Some of the older gadgets are not work on the newer version of the software without a little bit of tweaking.
In order to be 100% sure, I will need a little bit more information.
1. What product are you using?
2. What is the version of the product that you're using?
Also, in order for you to get up to speed on gadget coding, I would suggest watching the Gadget boot camp videos I am building.
Posted here: http://forum.vectric.com/viewtopic.php?f=48&t=33505&start=15
http://www.jimandi.com/VCarve-Tools/Videos/GadgetVideo.html
I am trying to put out one of these videos a week.
Jim
jimandi5000
Postby Adrian » Mon Dec 23, 2019 7:26 pm
To use those gadgets you have to have a job loaded. A blank new job is fine. They won't work if you try to access them directly from the startup screen of VCarve.
Postby jimandi5000 » Tue Dec 24, 2019 2:35 am
Adrian wrote:To use those gadgets you have to have a job loaded. A blank new job is fine. They won't work if you try to access them directly from the startup screen of VCarve.
Hi Adrian,
I am thinking that should be a validation check and on failure notifies the user to set up a job. Do you agree? If so, what do we need to do or who do we need to talk with, to have these gadgets updated and re-posted on the download site?
Jim
jimandi5000
Postby Adrian » Tue Dec 24, 2019 9:46 am
Hi Adrian,
The check is there but it doesn't work for some reason. They are Vectric maintained gadgets so issues with them would be reported the same way as a bug in the software directly to support@vectric.com
Return to Gadgets - General
