Code Error: Building and Using Lua Libraries
Postby jimandi5000 » Fri Dec 06, 2019 10:43 pm
Hi All,
I need some help...
I am trying to build/use code library. I am trying to reduce the number of lines I have to scroll through to fix and issue by being a stand alone code. As of now, I am getting an error.
Attached, is the code I have been testing and a screen shot of the error.
Your help would be GREAT!!!!
Test.lua
Code: Select all
-- VECTRIC LUA SCRIPT
-- require("mobdebug").start()
function main(script_path)
  local tl = require(script_path)
    local job = VectricJob()
    if not job.Exists then
         DisplayMessageBox("Error: No job loaded")
         return false ;
    end
    DisplayMessageBox(tl.Jim)
  return true
end
--  =============== End ===============================
Lib.lua
Code: Select all
function tool
tool.james = "{1,4,6,2,3,5}"
tool.bob = function(a,b); local c = 0; c=a+b; return c;  end
tool.jim = "Jim Anderson"
return tool
end
Libaray.zip
(594 Bytes) Downloaded 13 times
Jim
jimandi5000
Re: Code Error: Building and Using Lua Libraries
Postby Adrian » Sat Dec 07, 2019 12:09 pm
Busy working on my car today so haven't got time to look at the code in detail but two things strike me. First is where have the put the lib.lua file? If it's not on the package path then you need to define the path to where it's stored as part of the require call.
Secondly your lib file doesn't look to be structured as a module. You need to declare it as a module and then prefix the functions with the module so that the calling routine knows what it's calling. With the way it's structured I don't think Lua would see it as a valid module even if it could find it (if it's on the path).
Postby jimandi5000 » Sat Dec 07, 2019 11:12 pm
Hi Adrian,
Thanks for replying to my email.
I've made some modifications to the code (see below) and I'm still getting an error. Both files reside in the same directory location and I've tried both providing the full path with filename (test 1) and just the file name (test 2), resulting in the same error.
Lib file
Code: Select all
local M = {}
  function M.james()
    print("{3,4,6,2,3,5}")
  end
  function M.bob(a,b)
    local c = 0
    c=a+b;
    return c;
    end
  function M.jim()
    print("Jim Anderson")
  end
return M
Test File
Code: Select all
-- local tl = require(script_path .. "\\" .. "Lib.lua") -- test 1
local tl = require("Lib.lua")                                  -- test 2
         return false ;
    end
  return true
end
As always, I truly appreciate the help.
(5.24 KiB) Not downloaded yet
Jim
jimandi5000
Postby jimandi5000 » Sun Dec 08, 2019 4:01 am
Hello everyone,
I hope you're all having a great evening/morning/day wherever you're at the world. :)
I continue to have issues with making the lua module work correctly. I have installed Zerobrains and debugging the module works with the code below without error. (I do have to change the DisplayMessageBox to print for it to work correctly in Zerobrains)
Unfortunately, it does not work correctly when try I loaded into VCarve Pro version 10.018. I keep getting an error saying I'm trying to call a nul function.
There's got to be something I'm just plain out missing.
Any thoughts?
Test.lua
Code: Select all
local xx = require("Lib")
function main()
    DisplayMessageBox("Jim")
    DisplayMessageBox(xx.jim)
    return true
end
Lib.lua
Code: Select all
local M = {}
  function M.bob(a,b)
    return a+b
    end
  function M.jim()
    return "Jim Anderson"
  end
return M
Jim
jimandi5000
Return to Gadgets - General
